Aluminum suspension tubes-- 88 Rear Suspension with Rod Ends
Vendor link: http://www.racecareng.com/RCE1/item_det ... o=ALL56410
Manufacturer (part number list for different lengths): http://www.allstarperformance.com/product.htm?prod=861
Finished part list: phpBB/viewtopic.php?f=3&t=2573&start=60#p137290
Aluminum suspension tubes; come pretapped for 5/8" or 3/4", RH thread on one end and LH on the other. They're available in a variety of lengths and even have flats already machined in to make adjustment easy.
My original plan was to make similar parts out of steel.
These would not only make my life easier but they're cheaper too, and if I do hit a pothole and bend one, its a $10 replacement and I don't have to machine anything.
I would use these for the rear suspenion links on an 88 Fiero. 7/8" diameter 5/8" thread for the lateral links and the 1" diameter 3/4" thread for the lateral links. The sleeves for my poly bushings are 5/8" and 3/4" already so I have the rod ends ride on those. It's all plug'n'play!
You guys think these will hold up?
EDIT: Just changed the thread title.
EDIT #2: Added link to my finished part list later in the thread
Cool.
http://www.aurorabearing.com/
That's a lot of variety. I'll have to call and see what they'd recommend for the application. I don't like that I have to request a quote... that scares me. Are they friendly quotes?
Lots of racers use NMB bearings if they arent using Aurora
Here's a source:
http://www.bakerprecision.com/rodend.htm
Here's a source:
Tell 'em you want the Formula SAE discount.
:thumbleft:
:thumbleft:
The Dark Side of Will wrote:Cool.
The toe link is about 11 3/4" c-c and the lateral link is about 12 3/4" c-c.
McMaster-Carr lists some 5/8" greasable steel rod ends for $8.30 each. The distance from the proximal end of the threads to the center of the ball (Dim D minus Dim E in McMaster speak) is 1". The threaded shanks themselves are 1 5/8".
With 3/8" per end for jam nuts, the tube for the lateral link should be 10" long. This will thread the shank into the tube by 1 1/4".
For the toe link, the ideal length would be 9", but this wouldn't allow much room for adjustment. Stepping down to an 8" tube will give 1/2" (PLENTY) of adjustment at each end. The rod end would have 3/4" of threads in the tube, which I think is fine.
Just have to verify that the tubes are tapped 5/8-18 and not 5/8-11.
McMaster P/N's:
5/8-18 greasable steel rod-ends, male shank: 4444T4 ($8.30 ea; specify RH or LH threads when ordering)
5/8-18 plain steel jam nut, LH thread: 99612A159 ($5.82/pack of 10)
5/8-18 plain steel jam nut, RH thread: 94846A535 ($10.53/pack of 25)
If you REALLY want to spend some money...
5/8-18 Ultra strength rod-end, RH male threads: 4483T701 ($28.18 EACH)
5/8-18 Ultra strength rod-end, LH male threads: 4483T702 ($28.18 EACH)
www.chassisshop.com makes rod-ends boots to keep road grit out of rod-ends. These are absolutely essential for a street-driven application. Fortunately, they are also cheap.
Both ultra strength and greasable rod-ends are 3/4" thick, so they'll need spacers to work with the '88 cradle & stay parallel out to the knuckle.
This could be done for $130ish depending on what you use for spacers (washers will work on the inboard ends, for instance).
McMaster P/N's:
