Latest swap: 88 GT 3800 Series II SC & 5-speed getrag
General Information:
-1988 Fiero GT 39,xxx original miles
-2001 3800 Series II SC engine with 26 miles
-5-speed 282 Fiero getrag trans with a Gleason Torsen limited slip diff
-1995 OBD 1.5 engine management with one of my custom chips
-3.0" mandrel-bent exhaust split off to 2x 2.5" tubing to Monza tips
-3.5" ABS plastic induction tubing (GM duct p/n 25176891)
-K&N filter
-3.2" SC pulley
-1.8 ratio roller rocker arms
-Ported and polished cylinder heads
-Ported 3800 exhaust manifolds
-Billet fuel rails
-Walbro F20000169 255lph fuel pump
-Poly motor and trans mounts
-Functional R134a A/C system
-Late model electronic cruise control
-Battery relocated to front
-Crane FireWire plug wires
-Denso Iridium IT-20 spark plugs
-Custom AN/braded fuel and heater hose lines
-Sunbird Turbo boost gauge/tach conversion
-ARP stainless 12pt fasteners used almost everywhere visible
This is definately one of those "higher-dollar" swaps. The ARP stainless fasteners and AN fittings really ran the cost of this project up. However, that is what the customer requested and that is what was used. Notice my signature coolant fill point over by the right strut tower -- no ugly Fiero T-stat housings used here. Another first was the coil pack / 2bar MAP sensor / heater hose mounting bracket that I made. It neatly mounts to the stock battery tray. The stock 3800 dog bone bracket was welded to the tensioner from the same engine. A custom built (by me) alternator bracket mounts the 2001 GTP alternator to the stock 3800 P/S pump location.
Extra care was taken with this swap because of the low mileage of the car. The owner requested the swap be done so the vehicle could be seamlessly reswapped back to the stock 2.8 V6 in the event the value of a low-mileage, bone stock Fieros went thru the roof in the future. Pretty much every aspect of this swap was plug-and-play with the stock hookups of the Fiero so it could easily accept the stock powerplant if that was ever desired.
-ryan
Sinister Performance, LLC.
-K&N filter
-3.2" SC pulley
-Billet fuel rails
-ryan
Good question. The owner did the paint work himself and also bought a lot of the parts used in the swap before it got to me so I don't have a complete total cost of the swap. If I were to guess a dollar figure if you were to pay someone else to do EVERYTHING like it was done here; you are probably looking at $10,000 minimum.
The owner purchased the diff some time ago and yes, I believe it was one of the units that "resurfaced". If I remember what I was told correctly, the owner gave over $1000.00 for just the diff.The Dark Side of Will wrote:And he can spell Torsen.
Is that just a resurfacing of one of the few remaining?
I guess since he's concerned about mileage he won't be driving the car enough to blow the diff up any time soon.
