FOR SALE: 3.1 pistons
I have decided I am going with different pistons. 12:1 is just too high with boost. So I am getting rid of these.
Federal Mogul H562CP .040 oversized.
These are for a 3.1 iron head motor and is .040 oversized. With iron heads the compression ratio will be approx 8.8:1.
The skirts are coated with a teflon liner to reduce friction.
These retail for $30 a pop or about $180 for all 6. I want $110 shipped. They are still brand new and in the box.
THE PUNISHER
Post by THE PUNISHER »
Whyt don't you actually decide to do something with all these parts you have...
Selling that cylinder head rack any time soon?
Doug Chase
Post by Doug Chase »
So that would make these pistons something like 3.540"?
Are your compression numbers for a 3.1 or 2.8 crank? What's the compression height? I'd like to figure out compression in an iron head and aluminum head 2.8 to see if these will work for any projects I have in mind.
Doug Chase
Chase Race
Duvall, WA
these are 3.1 iron head pistons so I calculated the CR with a 3.1 crank.
You can't use these with a 2.8 crank unless you get custom rods. Compression height is stock for a 3.1 piston. I want to say 1.45 or something like that We had a chart posted here recently with all of that stuff.
But its the stock compression height.
With iron heads CR will be approx 8.8:1
With aluminum heads the CR will be abuot 11.8:1
Thats way too much for boost so I want different pistons for my al heads.
Yes bore size is 3.542 or there abouts with these pistons..
And Jon, you can lick my Ballzack
