Northstar Head Studs.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0320714737
Another genius graces the world with his ideas on how to fix the Northstar.
impeccable logic :lamer:
Also, 25 mile supercharged Northstar: http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0285217025
I think that the Thunderbird SuperCoupes have a similar layout. It's also the same layout as the LS9 uses in the ZR1.
The SC pulley is right above the crank in this pic (water connections for the AWIC are right above that):
You can also get an idea of the airflow path from this pic:
The throttle is right behind that rubber coupling. The supercharger inlet is behind that. The blower pushes the air up through the AWIC cores under the black cover at the top of the image, then down through the cast aluminum "towers" on either side of the throttle and into the cylinder heads.
If I had $6G's to blow on the thing, I'd rip all that shit off and turbo it... but that's just me.
