The first is an older model Smith & Wesson 5906. Popular gun back in the day, but now it's getting pretty obsolete. For just range shooting, I love the action. The first shot is double action, and has a long hard trigger pull, but from then on it's single action, and I love it, the shots just click off without barely touching it. Maintaining accuracy is easy. But, in the real world, should I ever need to use it, I could see it being unsafe, as with that much adrenaline, you can't effectively control something so touchy. The gun carries 15+1 in 9mm, and through 2500 rounds, I never had a misfire. Although, I did have a problem about 3 times in those 2500, where when the slide rode back after firing, the decocking lever (Which acts like a safety when down), would somehow fall down, and the gun would no longer shoot.
And here's the new gun, a brand new S&W M&P in .40 caliber. It carries the same amount of rounds as the 9mm (15+1). The biggest difference is weight. The M&P weighs significantly less than the 9mm, although they are nearly identical in size. The M&P is also a lot better in ergonomics, and is easier to manipulate. The slide doesn't have the decocker that tears your hand up, the mag release can be worked without moving your right hand, and the slide lock can be worked without moving your hand as well. I really like it!!! Plus it has a standard tactical rail, so I'm hoping to get a light for that here in the upcoming months. I've got 500 rounds ready, I'm hoping to hit the range sometime this week. Now I've got to figure out how to field strip it, and change the grips.
Also in the upcoming months, I'm going to get a baby M&P .40. It's the same gun, except with a shorter barrel, and a shorter magazine/grip. The full size magazines will still work, but the standard compact magazine is 10+1.
