Northstar Fiero Tear down 56K is for Queers.
THE PUNISHER
Post by THE PUNISHER »
Motor is back in.
Kohburn
FierHo
Post by Kohburn »
so what "things" did you redo/change ?
THE PUNISHER
Re-did engine mounts , (re-welded them and engineered)
Re did the coolant lines
Re routed some of the wiring better
Added Stupid trapps (Ugly but effective)
painted the tranny and cradle..
Re did the trunk (see pics)
Engine fired right up today first try.
Got the engine in yesterday and started up today , just have to fill with coolant and put the struts on and she's done.
Some pics of Mike STi's modified trunk to clear the exhaust , The Supertrapps (@ 5" in dia they should be called stupid trapps) The car is quieter and actaully runs smoother , not sure if it's the re-done wiring , or the backpressure.
Also it now has a wrinkle red Valve cover and a Glass black engine cover..to give that real welfare ferrari look.
Subaru's do get stuck...
The next project...56 Velam isetta..makes a smart car look like a fullsize truck.
JM
whipped
Post by whipped »
Urkelmobile?
THE PUNISHER
56 Velam isetta , the next project.
750 GSX-R with a single rear tire conversion and electronic shifters should do nicely
whipped
Post by whipped »
THE PUNISHER wrote:56 Velam isetta , the next project.
call it what you want it's still the Urkelmobile... :la:
