Rear bumper vent?
product1620
Rear bumper vent?
Post by product1620 »
Well, the last couple days iv'e been working on the fiero and trying some things out. I'm doing a hood vent; in fact ive already cut it out, I just need to finish sanding it. While I was working on the hood I kept thinking about other problem areas for trapt air. One that really stuck out was the rear bumper. I know of some drag racers who vent their rear bumper so as to allow the air that gets trapt from underneath the car to be vented. so what I did today was I took a two inch drill bit (the circluar ones used for makeing door knob holes) and put three holes on each side of the lower bumper near the tag. My question is do you think this will do a sufficient job of venting the traped air???
My camara's battery was dead today, so I will try to get pics tomowrow.
1998 Mustang GT
donk_316
Booooooost
Post by donk_316 »
ohhhh i gotta see this...
Resident Import Elitist
1991 Skyline GTR
(OO\ SKYLINE /OO)
product1620
Is that sarcasm I sense??? :la:
1998 Mustang GT
what drag racers do this? You talking of civics? I think I know what you are talking about but I want to see whats really on your mind.
MNFatz
Re: Rear bumper vent?
Post by MNFatz »
product1620 wrote:Well, the last couple days iv'e been working on the fiero and trying some things out. I'm doing a hood vent; in fact ive already cut it out, I just need to finish sanding it. While I was working on the hood I kept thinking about other problem areas for trapt air. One that really stuck out was the rear bumper. I know of some drag racers who vent their rear bumper so as to allow the air that gets trapt from underneath the car to be vented. so what I did today was I took a two inch drill bit (the circluar ones used for makeing door knob holes) and put three holes on each side of the lower bumper near the tag. My question is do you think this will do a sufficient job of venting the traped air???
Let me guess. Fast and the Furious?
(if not, the license plate lite mounting holes I'm sure do the job...)
product1620
Shaun41178(2) wrote:what drag racers do this? You talking of civics? I think I know what you are talking about but I want to see whats really on your mind.
I'll try and get some pics tomowrow. I'm not sure of the exact racers, but I know ive seen this done to some of the street/strip cars.
1998 Mustang GT
product1620
Umm, no. I, unlike a lot of people, don't take those movies seriously, and certainly don't use them as a reference for performance tips. :angel:
Those are like what a half inch by and inch, I don't think that is going to vent too well.
1998 Mustang GT
slow'n'steady
Post by slow'n'steady »
a while ago when i had my neon, i was on neons.org a lot and i remember reading about this EXACT same thing. the guy cut 6 2" holes (3 on each side) then laid wire mesh behind. looked kinda dumb to me but he reported something like 12-16 more miles per tank of gas.
Personally I'd take a sheet of fiberglass and block off the bottomside so air can't get above it, but I guess your way takes away weight instead of adding it...
product1620
slow'n'steady wrote:a while ago when i had my neon, i was on neons.org a lot and i remember reading about this EXACT same thing. the guy cut 6 2" holes (3 on each side) then laid wire mesh behind. looked kinda dumb to me but he reported something like 12-16 more miles per tank of gas.
I think it looks decent, but it dosen't really matter to me anyway, cause i'm more into function than form (at least when it comes to cars :la: )
1998 Mustang GT
Then why not take the bumper off?
product1620
Aaron wrote:Personally I'd take a sheet of fiberglass and block off the bottomside so air can't get above it, but I guess your way takes away weight instead of adding it...
That is my main reason for doing it this way, and plus it simplifies the whole thing. The weight savings is also the reason I chose to just cut out the hood vent rather than using and add on peice.
1998 Mustang GT
product1620
Aaron wrote:Then why not take the bumper off?
Then where would I mount the license plate? :la:
Honestly, I don't want it to look like complete trash, but somthing as small as bumper vents dosen't bother me.
1998 Mustang GT
slow'n'steady
well, then why not form and function? i just think the six Os would look goofy, ESPESCIALLY on a fiero!! maybe a couple like 2" X 6" rectangular holes or something? i just think if you wanna do it, it would be pretty easy to make it functional, yet not obvious that you just took a hole cutter to the bumper... i wish i could find the pics of the neon that did it, then you;d see what i was talkin about.
Interesting... How did he arrive at this conclusion? IOW... did he record his data and compare fillups to the odometer, or did he just use the ass-o-meter? That's an extra 1.5 mpg or so, guessing the Neon's tank to be about 10 gallons.
whipped
Post by whipped »
speed holes!
Pyrthian
Post by Pyrthian »
exactly. real racers use belly pans to keep the air from being trapped in the first place.
slow'n'steady
well i dont remember exactly how it all wwent down, but somethng like he was visiting a friend in another state, and recorded the odo/fuel on the way down there, ended up cutting the holes while there, then took the same route back recording odo/fuel and ended up something like 10-13 further or somethin like that.... its on the neons.org website, i looked for a few minutes but gave up, it was prolly like a year ago when i read it.
Kohburn
FierHo
Post by Kohburn »
sounds like too small a change to base anything on - especially with a reverse trip with uncontrolled conditions
Pyrthian
Post by Pyrthian »
Kohburn wrote:sounds like too small a change to base anything on - especially with a reverse trip with uncontrolled conditions
it was uphill, both ways....
