EGR tube gaskets for 2p8
I need the gaskets that seal the EGR tube to the manifold & EGR valve. CarQuest doesn't have them listed as such, although they may be in the EGR valve gasket set.
Anybody know where I could get these? Fierostore?
don't know if the 2.8 egr gaskets will work. Not sure if they are the same as the TDC gaskets. If thats what you need them for is a TDC then I prob can't help ya.
Summit stocks exhaust gasket material sheets. Something like $5 for a sheet 12 by 12 inch square.
Of course you'll have to find something else to buy--the handling charge will be more than the purchase.
edit: Here's the part number: PHP-68006. unfortunately it looks like they're out of stock until 9/15.
