Stiffen the unibody with polyurethane?
That re-inspires my interest in doing this to one of my cars... or a whole lot of my cars. His descriptions of better feedback and controllability are especially intriguing.
Once I figure out everywhere to squirt the stuff and develop a reasonably effacacious way of measuring chassis stiffness, I have enough chasses to try 4#, 8# and 16# foam in them to see if the difference is worth the weight gain. I wouldn't mind adding 50# to the car for a 25% increase in torsional stiffness.
Sources for the foam they used:
http://www.foampower.com/store/two_component/index.html
http://www.marinefoam.com/liquid-sprayin-foam.htmlor at Grainger (this one is the II-12 kit, smaller capacity vs. the II-22 kit, credit goes to Epstein, he found this at Grainger)
http://www.grainger.com/Grainger/wwg...mId=1611574493
Last edited by The Dark Side of Will on Sat Apr 14, 2007 2:25 pm, edited 1 time in total.
what's a "board foot" and how does it relate to volume?The Dark Side of Will wrote:Sources for the foam they used:
http://www.foampower.com/store/two_component/index.htmlor at Grainger (this one is the II-12 kit, smaller capacity vs. the II-22 kit, credit goes to Epstein, he found this at Grainger)
S2000 use of liquid sound damper: http://www.s2ki.com/forums/index.php?showtopic=275932
Just collecting all the links from the other threads:
http://www.itwfoamseal.net/auto_aftermarket.htm
http://www.sportcompactcarweb.com/proje ... index.html
not yet - probably in the next few weeks. leaving for vacation friday.The Dark Side of Will wrote:Pics in your house building thread?Kohburn wrote:since I bought a spray foam insulation machine I am buying this stuff both .5# and 2# foams by the 55 gallon drum. sprays in at about 150* and hardens fully in about 30 seconds.
This would be good for those going targa correct?
Fiero Build Thread here:
I mean in addition to bracing underneath the car. At this point, I'm pretty sure I want to go with a targa top on my car so I'm looking into anything to add the extra needed stiffness to the frame.
