Anyone know of a source for the 88 rear inner sway bar bushings?
Thanks!
88 rear sway bar bushings
Oh, I forgot to mention this. I made a set of rear sway bar bushings, I used a set of Moog thermoplastic rubber sway bar bushings from a late model Cavalier with a 22 mm bar.
Not a direct replacement, but 5 minutes at the bench grinder was all it took to grind down the center to fit in the stock bracket, and trim a little off the bottom. The Cavalier bushing is a bit beefier, but it is large enough to shape it so that it has shoulders on either end to hold it in place like the stock bushings.
I'll try and remember to take the camera to the shop and get a pic.
