From 6k on, looks like I was right.Series8217 wrote:Here's my completely NA DOHC dyno at exactly sea level. You can see the correction factor is 1.00 due to the nice conditions that day. Mods are custom intake, some porting of the manifolds, balanced and blueprinted: http://www.pbase.com/series8217/image/8 ... /large.jpgdarkhorizon wrote:At the end of your run your making 160whp, isnt that like 30-40whp less than what a stock dohc makes at that rpm?
Here it is overlayed on Aaron's:
blue is hp, red is torque.
Think it's about time to spin some rollers (Aaron's dyno)
Wow, for a 1000 RPM stretch that I will never be in, save for a fraction of a second, Steven's car makes more power.
Then I shift.
I'm still amazed how you manage to completely miss the fundamentals behind how a wastegate works. It's baffling that people pay you to touch their car.
Then I shift.
HAHAHAHAHAHA!!!! Lol, that's like perfect!
I like how the lockness goes down, into a safe AFR range, as brutal power comes on. But then it rises from the depths midway through, to impress people with that maximum power AFR. Then, whilst people's jaws are ont he floor, it dives again, gone until the end. Truly spectacular tuning.
for the most control of a wastegate you want it as the priority.
3lbs of resistance is boost really.
pretty much all of the wastegates i know up, except mine, use rubber diaphrams. running a wastegate the wrong way would promote more resistance, which means more heat. that is if i'm jumping in on the conversation right.
my fiero is faster then yours. the end. except you fieroX
on 14 psi. Meh. It should be higher wiht your larger turbo then what matt has.Aaron wrote:
As I said before, take the CF, divide it in half, then apply it, and that will be roughly what my car is realistically making. 376whp.
Systems Integration FAIL. Piggyback FAIL.Aaron wrote:I had a setting wrong on my FTC1, and it was only reading half RPM (So idle was at 450).
Bragging rights = zero.
Right back at you, tough guy. You don't have a technical argument for why it should work because you don't understand it.Aaron wrote:And your technical argument why it wouldn't work?
Oh, you don't have one, because you don't even understand how they are supposed to work.
And if you had a boost controlling ECM, you could set your boost to a MAP value and we wouldn't be having this argument.Aaron wrote: I have my WG setup to atmosphere reference, not like on, say airplanes, where they use the vent port on the WG to overcome the affects of altitude.
