Posted up in the bathroom at work. The sharpie marker was my doing... :la:The Dark Side of Will wrote:Systems Integration FAIL. Piggyback FAIL.Aaron wrote:I had a setting wrong on my FTC1, and it was only reading half RPM (So idle was at 450).
Bragging rights = zero.
Think it's about time to spin some rollers (Aaron's dyno)
I dynoed at 376 whp with my turbo L67 at 14 psi and that's with a 60-1. :salute:Aaron wrote: So my 417whp is 334 uncorrected, and realistically, about 376whp. Still better than every other car on this forum if I'm not mistaken. Lastly, I'm pretty sure every other turbo dyno was corrected for altitude.
'89 Olds Cutlass Ciera International Coupe - '99 L67/4T65EHD, 4" intake, 3.4" pulley, PEMs, full 3" exhaust
13.755 @ 102.91 with a 2.266 60'
And yet, you have to be seen in a Oldsmobile Cutlass. I'd sooner shoot myself.
And how does your A:F chart look?
So, you're making 450chp, at least, and you can't do better than a high 13? Ouch. That's pathetic. It's a good thing you get to lube up your ovaries driving an automatic, front wheel drive, ugly-ass gm piece of shit in the mean time. And you're 60' time is terrible. My 15 second Lumina did better than that!
Running good. I haven't had the time to truly tune it though, nor call Split Sec to figure out the rpm pickup error. I guess I could do that now though.
I did change the numbers in the cells it is using, and it liked that a whole lot, and the AFR seems pretty stable at 12 in 1-3 gears. Which, those are the only I go WOT in, so it pretty much takes any motivation I had to do the tuning in 4th. But someday I'll get around to it.
Nothing's broken yet, but I've also turned the boost back down in fear of that. As I've said all along, it's got the potential to make a lot of power, and if it had the block to handle it, I'd do it in a heartbeat. But until I can afford/get motivated enough to buy a 3.6, I'll limit it to 8.7psi. And it still hasn't bored me yet at those numbers!
That's not a result of the engine though. Same thing would have happened with any engine.
My eyes are wide open, let me know if you find anything out there. I'd go to Cali to pick one up. I do know of one 88 coupe out in Cali, the paint's a bit ugly, but it had a pretty engine :thumbleft:
I think it's clearly evident by my signature that I have not updated it since I did the turbo swap. Were you to actually look at the mods you would realize that those times are from when it still had the M90. As far as looks are concerned, that is a matter of preference. I will say that Fieros generally look better but my Ciera is probably not what you think of when you think of a Ciera. I find it amusing that you stated that no one on this board made as much power and when I point out the contrary you just post silly insults.Aaron wrote:And yet, you have to be seen in a Oldsmobile Cutlass. I'd sooner shoot myself.
So, you're making 450chp, at least, and you can't do better than a high 13? Ouch. That's pathetic. It's a good thing you get to lube up your ovaries driving an automatic, front wheel drive, ugly-ass gm peice of shit in the mean time. And you're 60' time is terrible. My 15 second Lumina did better than that!
As far as the A/F ratio is concerned, I tune with a Innovative LC-1 and it's rock solid ~11.8:1 at WOT at all rpms.
EDIT: I would also like to add that regardless of what car my engine is in, it still put down the same power with a slightly smaller turbo through an automatic.
So what happened? How bad is the damage?Aaron wrote:Eh. It was that, among other things. Not paying attention didn't help, nor did bald tires. Oh well, shit happens. Like driving off cliffs.
Edit: I assume you're ok, yes?
<Insert Sig Here>
A-bodies may not be pretty, but they're straight out of Star Trek in that they have cloaking devices and are utterly invisible to police.skalor wrote:As far as looks are concerned, that is a matter of preference. I will say that Fieros generally look better but my Ciera is probably not what you think of when you think of a Ciera.
I guess with 5 posts, none of them showing anything you've done, I somehow missed your build thread or dyno results. My bad, I guess....skalor wrote: I think it's clearly evident by my signature that I have not updated it since I did the turbo swap. Were you to actually look at the mods you would realize that those times are from when it still had the M90. As far as looks are concerned, that is a matter of preference. I will say that Fieros generally look better but my Ciera is probably not what you think of when you think of a Ciera. I find it amusing that you stated that no one on this board made as much power and when I point out the contrary you just post silly insults.
Your Ciera is fucking ugly, and yes, it is what I think of when I think of a 1980s Oldsmobile.
Just because he doesn't post HERE doesn't mean he doesn't post, genius. He's got better things to do than gain your approval.
http://www.a-body.net/forums/showthread.php?t=110
I drove head-on into a 1995 Ford Taurus in the Home Depot parking lot. Luckily I didn't have my freshly painted fender and rocker on, so those are good. But my bumper, hood, passenger fender, and the frame are done. I'm going to rebuild the car on like an 88 coupe frame. I also need a new headlight.Fastback86 wrote: So what happened? How bad is the damage?
You drove into the Ford? How'd you manage that?Aaron wrote:I drove head-on into a 1995 Ford Taurus in the Home Depot parking lot. Luckily I didn't have my freshly painted fender and rocker on, so those are good. But my bumper, hood, passenger fender, and the frame are done. I'm going to rebuild the car on like an 88 coupe frame. I also need a new headlight.Fastback86 wrote: So what happened? How bad is the damage?
<Insert Sig Here>
