Posted: Fri Apr 08, 2022 9:10 pm
Last weekend I got a couple of small things done, as well as a bunch of lines on the wire list.
Added a T to the oil pressure elbow in order to make a fitting tree. The oil pressure transducer should stick out over top of the cradle crossmember, while the switch/sender should hide behind it. I'll have to turn the wiring tight so that it doesn't hang down below the bottom of the pan.
I clocked the alternator rear case in order to bring the stud close to the block and bring the rear mounting boss close to the existing hole in the bracket. The bracket doesn't fit because it was designed for a CS144 alternator and this is a CS130.
A longer shot down the side of the block. Yes, I'll have to do a lot more modification to the bracket in order to use the stud. I just drilled the hole quick and dirty in order to get everything into relative position.
Accessory drive with belt. I hope it clears the battery tray.
Closeup of the bracket... All I really did was move the tensioner and the idler... and the top alternator mount a little bit
And the junction block + mount bracket, before I drilled the mounting holes
