yeah thats what I was thinking - it makes a good alternative to water alchy spraying for a 3800sctxf wrote:The CO2 will probibly eliminate teh need for the H2O injection. Cooler Air means less spark retard needed.
CO2 chillers
The Co2 thing is interesting, but I think as far as FI engines go, I would rather spray a 50/50 mix of meth/h2o. Not only does the vaporization of the mix cool the intake down, the alky is aobut 110-120 octane rating depending on what kind you use. Also, the steam created by the water will help remove carbon outta your combustion chamber, the back side of your ex. values and your valve faces.
Sure co2 cools your intake temps way down, but there is a point of diminishing returns when your fuel doesn't want to atomize and stay suspended in the intake runners.
If you ever see an alky dragster's carb, ice is always forming on them because of the temp drop created by alky.
Just seems that if you can drop temps, steam clean pistons and raise octane its a better way to go for a FI engine.
But hey, someone test it out and see what does better, then we will really know since all of this is just speculation lab crap![Smile :)](./images/smilies/smile.gif)
well on the series 3 3800sc's liquid injection is a bad idea since the SC rotors are coated oversized and running the engine wears the coating in to hold closer tolerances - this coating can be blasted off by the liquid - however pre-chilling the air will give the SC an extra dense cold charge to make it more efficient plus it will heat the air from compression and conduction so atomization of the fuel where it enteres after the SC shouldn't be any worse than stock.teamlseep13 wrote:The Co2 thing is interesting, but I think as far as FI engines go, I would rather spray a 50/50 mix of meth/h2o. Not only does the vaporization of the mix cool the intake down, the alky is aobut 110-120 octane rating depending on what kind you use. Also, the steam created by the water will help remove carbon outta your combustion chamber, the back side of your ex. values and your valve faces.
on a turbocharged car having that inline before the turbo with a normal intercooler after the turbo could be interesting.. cold dense air entering the compressor side could be a huge bump in efficiency
I think it'd be interesting to experiment with
