SappySE107 wrote:your intake setup is more likley for 9000+.
Then I'll add a few inches to the runners. Wow that was hard...
"I will still be building my independant throttle body setup, and I will dyno it on my red car, and then sell it. It is perfect in every respect, and the best intake that could EVER be put on a N/A engine"
Your point? It is true. Maybe not mine in peticular, but there is no beating the independent throttle body setup, whether you want high or low RPM. Or even boost.
Again, your point? If he wants to buy a chip, your chip is the way to go. Although expensive, it offers the most performance gains, and you update it for free. Now I have proof that the factory A:F ratios up to 6000 are damn enar perfect, but after that, they do go rich, and power goes down. If someone wants a chip, your's is a good investment IMHO. Although I think you overrate your own work, burning these chips isn't very difficult, and there isn't much that nees to be done as far as fueling goes on a stock MPFI setup.
[quote
aaron trying to argue his intelligence with a shop owner with a dyno. The great debater at work! Notice all the incorrect shit he states, like "got 198 hp on a stock motor" or his thinking that the flow numbers mean everything when it comes to performance.
[/quote]
Sorry, he gained 20whp with an exhaust that doesn't help and a chip that didn't need to be done. And this is assuming his motor runs better than mine, and I have a brand new fucking crate engine. Sorry, I doubt it runs stronger than mine stock for stock.
And don't even deny you didn't doubt his claims. Wet flow is great, but there is only so much you can do. And the restriction isn't the heads when they flow 280cfm stock. The exhaust could use help, but I'm not seeing 80 wheel horsepower, from heads, exahust, and tuning. There is not that kind of power to be had from working on these heads. You know it as well as I do. If that were true my Fiero will dyno at more than 300whp, EASY. Bullshit. It won't crack 250, and I know it.
(This is with my ported/polished/reshaped heads, stock intake manifolds, stock exhaust manifolds, 13* retard, short 2.5" exhaust, EWP, no A/C, no P/S, and on top of all that, a MAF car. Bullshit I'll crack even 220. It isn't happening)
