Posted: Fri Oct 20, 2006 3:02 pm
But it screws up the way the air is *supposed* to flow through that grate...
i also think that without the airflow coming up out of the grate and filling the area behind the window that it would create additional drag at speedThe Dark Side of Will wrote:But it screws up the way the air is *supposed* to flow through that grate...
I am also using the stock 87 front bar with the stock 88 rear bar on the 88 rear suspension. I have the front koni's at about 3/4 full hard and the rea is at full hard. I also have 350lb rear coil over springs and 325lb front springs. I'm running 205/50/15 tires in the front and 225/50/15 in the rear. The staggered tires has helped the understeer a lot. There still is a little bit, but not much. Next season I think I might try a wider rear tire if I can find one. I will probably have to go to a 16" wheel.Jinxmutt wrote:Yea, but i have the 88 rear bar, and a factory front bar. That would make the rear bar larger, whereas your bars equal. Thats not counting the length of the arms like you mentioned.
As I said earlier, it could be my driving, I could be coming into the turns too hot, but I find that with my car at my current (lack of?) skill level, just about halfway through the turn my car switches to on the edge of understeer, to slight oversteer. Before I had the pzero on the front, all the car did was understeer, so it could also be a tire balance I need to work with.
Need more seperation than that. 215 front with 275 rear will work well.Dough19 wrote: SInce you have way more torque than I do, I would recomend you go as wide as possible on the rear, with a coresponding narrower tire up front. 275 in the rear and 255 up front might work nicely.
