n/m... must have been a long daySeries8217 wrote:What are you talking about? The slave doesn't even move when you try to bleed with the non-gravity method. The fluid retracts when you let out the pedal and there's a big fucking vacuum left behind that makes the seal useless and air gets in.
The factory slaves have an o-ring behind the umbrella seal so they can seal at least a bit when there is no fluid pressure, that way the vacuum draws fluid from the master cylinder reservoir as the master cylinder piston retracts, rather than drawing in air.
Clutch Bleeding
