Why are you apologizing to me?chuck wrote:I got the 3900 dyno'd. Sorry sinister, the shop talked me into just making the changes.
replacing my 3900 exhaust, need advise
Re: replacing my 3900 exhaust, need advise
u able to post up the graph of the dyno runs?
we were talking about you doing the tune through the mail but the shop that did it last time wanted another go at it. I was still going to send the chip in today to have a few changes made and have you take a look at things but there is a car show on the first so it'll have to wait another week. I did get to the quarter mile but due to a flat on a buddy's trailer we got there late and it was pretty hot and humid out. the best run I had was 13.88 and I bounced off the rev limiter. I'm going to need that raised a little bit because the 1-2 shift is too much drop for the engine so I need to really wind out first gear to keep me above 3,300 in second. 2-3 shift is good, I can get away with shifting around 6,000rpm. I have a hesitation after throtttle tip in under light throttle. Fuel economy is good but I figured since it's there I may as well have highway fuel mode turned on. I'm still a little low on power according to sappy/60degree's estimate but at this point it probably is what it is unless I start raising compression or turbo. The tuner printed out the tune and max timing is 39*. Superdaves is 34* if I remember right. That's why I would feel better if you at least looked things over. I'll have it in the mail next week.
I can email the dyno graph if you want to post it. I got a new computer and am having problems.
I have absolutely no problem with that. No apology was needed.chuck wrote:we were talking about you doing the tune through the mail but the shop that did it last time wanted another go at it.
I would be happy to look things over. But it would be better if you could get a scan log and send that too (something that shows knock retard, fuel trims, and O2 mv / wideband O2 readings). If you just send me a copy of the tune; I will be able to tell you what things are set to, but I have no idea if your engine actually likes these settings or not. Should be no problem in raising the rev limiter tho...chuck wrote: I was still going to send the chip in today to have a few changes made and have you take a look at things but there is a car show on the first so it'll have to wait another week. I did get to the quarter mile but due to a flat on a buddy's trailer we got there late and it was pretty hot and humid out. the best run I had was 13.88 and I bounced off the rev limiter. I'm going to need that raised a little bit because the 1-2 shift is too much drop for the engine so I need to really wind out first gear to keep me above 3,300 in second. 2-3 shift is good, I can get away with shifting around 6,000rpm. I have a hesitation after throtttle tip in under light throttle. Fuel economy is good but I figured since it's there I may as well have highway fuel mode turned on. I'm still a little low on power according to sappy/60degree's estimate but at this point it probably is what it is unless I start raising compression or turbo. The tuner printed out the tune and max timing is 39*. Superdaves is 34* if I remember right. That's why I would feel better if you at least looked things over. I'll have it in the mail next week.
Let me know.
-ryan
When you make a post, right under the submit button there are two tabs. one is labeled "options" and the other "upload attachment" Click on the upload attachment, and you can upload a pic onto the site, right from your computer.chuck wrote:I can email the dyno graph if you want to post it. I got a new computer and am having problems.
this is both. low one is last year with stock cam and shorty headers. The high one is cam, long headers and 3.73 gears
- dyno.jpg (94.19 KiB) Viewed 2933 times
my iphone doesn't like time slips but
60'-2.026
330-5.797
1/8-8.892
mph-79.80
1000-11.595
1/4-13.886
mph-96.58
Any advise is appreciated. I tried power braking on the second run but creeped and lost the staging light. third run I shifted early to avoid the rev limiter but ran a 13.96. I'll practice a bit and have those few issues looked at and go back when it's cooler.
60'-2.026
330-5.797
1/8-8.892
mph-79.80
1000-11.595
1/4-13.886
mph-96.58
Looks like a decent power improvement Josh, and the 1/4 miles times aren't bad. I'm sure there is room for improvement!
Thanks, I'm thinking with some fine tuning, cooler weather and a better launch it'll do 13.5 but I don't know where to go from there. I do have a 4speed manual but I'm not ready for that yet.
