Parts & Materials Library / Hard to Find Parts
Re: Parts & Materials Library / Hard to Find Parts
Possible exhaust port fill material for those doing SERIOUS head work:
http://www.akd-tools.gr/xmsAssets/File/ ... 346(1).pdf
OE fuel rail quick connect to AN adaptersKohburn wrote:(summit)
Russell Pressure side fuel adapter #640860 $12.99 (3.4)
Russell Return side fuel adapter #640850 $13.39 (3.4)
Re:
Xanth wrote:Possible alternative to the OEM Fastback trunk gasket:
http://www.jcwhitney.com/autoparts/Item ... 0000163412
Gasket mounts at a right angle, putting it in the correct orientation for use on the fastback trunk.
This looks like it very possibly may work for A-body door weatherstrip also.
Here's the page with all the different styles: http://www.jcwhitney.com/autoparts/Prod ... atherstrip
Oil Gallery brushes from Pioneer Automotive (have not looked in the Pioneer catalog yet).
Summit P/N: PIO-4501 (no picture)
I just ordered a couple. I'll update when I get them.
NAPA/Echlin part # 2-12085
Ford style Bosch injector seal kit; includes 2 o-rings, 1 spacer and 1 tip/nozzle/pintle/dohickey.
http://www.fivestarclamps.com/
Band clamps (including constant tension spring loaded)
V Clamps
Barrel Clamps
Other Clamps
Multitudes of sizes
Canton shipped a pair of these to use to mount their Accusump.
V Clamps
Barrel Clamps
Other Clamps
Multitudes of sizes
Steel and aluminum suspension tubes with greasable rod ends:
http://www.pitstopusa.com/Categories.aspx?ID=3381
Note that the measurements are the length of the tube, not the distance between the center of the pivot points.
http://www.browellbellhousing.com/
Custom bellhousings.
http://www.dellowauto.com.au/main.html
Lots of adapter bellhousings, but in Australia.
http://www.genesisautoparts.com/all_alu ... -fiero.htm
All aluminum drop-in radiator. Almost certainly made in China.
I'd like one without the trans cooler, though.
Heater hose for the 3.4 DOHC factory oil cooler inlet from the block: Dayco 87617. This isn't listed in an application book anywhere, but works great. You may have to trim a little bit off it. Available at most auto parts stores for $7 or so.
Ctrl-F "Variation Nut":
http://www.serpentautosport.com/HTML/Hu ... acers.html
These nuts allow wheels and hubs with slighly mis-matched bolt circles to be assembled. They could be used to:
Mate 120.65mm (4.75" Chevy pattern) to 120mm (BMW pattern)
OR (as relevant to the Fiero community)
Mate 114.3mm (4.5" Everything but GM pattern) to 115mm (GM large FWD pattern)
This satisfies my OCD with regard to avoiding side-loading the lug studs with slightly mismatched patterns.
Obviously use of these requires that appropriate attention be paid to adapting center bore diameters to keep the wheel hub-centric.
Since they haven't been specifically mentioned earlier in the thread, tubing donuts can be had from The Chassis Shop:
http://secure.chassisshop.com/Default.aspx?PBURL=/
Remote mount marine waterpumps: http://www.ittflowcontrol.com/jabsco/engine-cooling.htm
I saw one of these: http://www.ittflowcontrol.com/marine-an ... 4-pump.htm used on a BBC in an offshore racing boat.
Meziere also makes a remote mount mechanical waterpump: http://www.meziere.com/ps-1224-1191-wp430s.aspx
Moroso has remote water pump adapter kits for SBC and LSx (scroll to the bottom of the page for the adapter fittings): http://www.moroso.com/catalog/categoryd ... code=29300
Dedenbear ( http://www.dedenbear.com/TXTwHead.htm ) has a water manifold to work with remote mount waterpumps. It's available from Summit ( http://www.summitracing.com/parts/DED-WH1/ ). I thought that Offenhauser made a similar piece, but I can't find it anywhere.
http://www.professional-products.com/ManifoldAcc.php
Ctrl-F "Manifold bushings"
These allow the mix/match of SBC intake manifolds and cylinder heads that have the middle bolts angled/straight.
Delphi Connectors and mucho other electrical and harness materials/equipment:
http://www.pcsconnectors.com/
LED Replacements for 194 type bulbs used in Fiero marker lights and MANY other applications:
http://www.superbrightleds.com/cgi-bin/ ... wedge.html
Also includes the twist-lock type socket used in instrument panel back-lighting.
Detail pages:
http://www.superbrightleds.com/cgi-bin/ ... ckets.html
http://www.superbrightleds.com/cgi-bin/ ... ED-xLX.htm
Detail pages:
Integrated remote oil filter adapter and starter mount for small block Chevies. Claims to be able to work with 142 tooth starter ring gear. Interesting.
http://www.hylube.com/products/msrkit.htm
Eastwood fender rolling tool (yes, I know it doesn't have any use on a Fiero...):
http://www.eastwood.com/ew-fender-rolle ... ction.html
The mythical SBC block with FWD bellhousing pattern: http://www.jrgmparts.com/GM_Performance ... all_b.html
P/N: 24502650
I'm sure it's plenty expensive though...
P/N: 24502650
