Finally finished up a leveling and mounting system for the block and cradle that's also mobile around the garage...
It's a harbor freight furniture dolley with 4 added castors under the center section made up of two additional 1x12's... took some metric threaded rod into several of the oil pan bolt holes with some couplers and threaded rod feet to stand the engine up for leveling...
The oil pan's oil pan drain bolt, the lowest part of the engine is .5" above the bottom of the cradle...
Temp suspension links attached and brought to parallel and aligned with output shaft holes of F40 with lateral links at level resting ride height. As you can see I'll have about a 5deg slope down from the F40 to the hubs... no problems there...
...and that's about as low as I can comfortably get the LF3/F40 combo...
Next up was centering the engine/tranny onto the cradle laterally and broke out the cobalt LNF axles to attach the fiero axle stubs and center everything up...The bad news is that any rumors of the 08-12' Turbo Cobalt beefy axles being plug and play with the fiero axle stubs is bollocks.....
The fiero star in it's outboard joint has no chance of mating up to the Cobalt LNF Turbo axle shaft... 1.25" vs 1.75" diameter.... which does give plenty of meat to have the ends of the cobalt axles resplined to that of the Fiero / Cobalt LSJ. Going to call TheDriveShaftShop tomorrow and see if they can take care of that.. This will effectively, from what I've researched, turn the LNF axles into the same ones sold with the GM performance parts Cobalt Wheel Hop Kit they came out with around 2008/2009 for the LSJ Supercharged Cobalts, LNF axles resplined with the LSJ axles stubs.
