Trying to Figure out an MPG Problem
Alright this isn't my car, its a friends. When I got my hands on his car it was idling at 2,000rpms+ and getting 12 mpg. I put in:
A new Stant 195* Thermostat
New Purolator Fuel Filter
New Purolator Air Filter
Blocked off the EGR Crossover (it was cracked, hence the idle) blocked off the necessary vac lines
Cleaned the IAC off with some pb blaster
She idled at a nice 900rpms and was purring. His passanger side front brake caliper was dragging I guess because the car pulled right and that wheel was covered in brake dust. He had a new line installed, new caliper, and new pads up front. No more pull, no more dust. Also he put in a test pipe in case the stocker was clogged, put in a new set of NGK UR5s, and seafoamed the motor.
He calls me yesterday, 3/4 of a tank got him 80 miles, so his mpg is getting worse. His idle is still good though, but he is running really rich.
Before he bought the car they put in a new O2 sensor and he has the receipt.
So what is it??????
Someone said the IAC could be bad? or the coolant temp sensor? Old Europe suggested dumping injector cleaner in it, which he did, and that didn't help.....
Any ideas?
So what is it??????
Any ideas?
He bought the car used, but the previous owner gave him a receipt saying he had the O2 replaced recently. I don't remember seeing leaky injectors when I pulled the upper plenum. I called him and told him to get a coolant sensor. Hes an hour away from me, I am going to try to get up there in the near future to check out that car, but I think its 2 weeks off at the shortest. Hes a student and 100 miles per tank its getting un-affordable. I may be buying a Silver 87GT soon lol.
he also said he thinks his exhuast manifold is cracked, but it was cracked when I fixed the 2000idle and it was still cracked when the brake got fixed. Yet his car is getting worse. Would a cracked manifold mess him up that much?
That is my current theory as well, is it possible the crack is growing?The Dark Side of Will wrote:Leaking exhaust manifold can make it run rich (maybe not as rich as you describe, though). Air actually gets pulled in through the leak between exhaust pulses, making the O2 sensor think the engine's running lean. The ECM richens the mixture to compensate.
Another symptom of this is that it should also pop loudly and maybe blow out your muffler coasting down from high RPM.CincinnatiFiero wrote:That is my current theory as well, is it possible the crack is growing?The Dark Side of Will wrote:Leaking exhaust manifold can make it run rich (maybe not as rich as you describe, though). Air actually gets pulled in through the leak between exhaust pulses, making the O2 sensor think the engine's running lean. The ECM richens the mixture to compensate.
CincinnatiFiero wrote:Hole in the gas tank is kind of obvious, its not that, and he said gas isn't leaking anywhere. I am pretty much positive at this point that its the header.
A "leaky" Cold Start Injector is one that is stuck open and leaking fuel into the lower intake manifold and thus right into the cylinders and making your car run rich. If the manifold doesn't fix the problem, I'd check the Cold Start Injector next.
<Insert Sig Here>
I think a coolant temperature sensor is a possibility if the manifold doesnt fix it. The sensor could be reading maximun cold all of the time and the ecm sending the signal to run rich all of the time as a result. If that is the case I think that could cause the cold start injector to run constantly since it never sees the coolant warming up...
