I was wondering about the feasibility of this. I have a GT turbo with the floating journal bearing center section. It's a big mofo, and ball-bearings are something cool to brag about, and they even help performance too! I want that thing to spool before I start the car up!
Ummm...anyway...How much of a pain might it be to swap in a ball-bearing center section? I've searched the net and can't really find much about doing it, so it's probably not done very often. I know I would have to have it re-balanced, what else might be an issue? I've been searching through the Garrett specs trying to find out if they use the same shaft, but haven't found anything there either.
Nate
Changing turbo center sections?
