Possible mount problem?
KMisery
Post by KMisery »
I have an 87 GT that I bought last August. And I noticed when I turn a corner, and accelerate, the tranny spins much faster than it should.
And I was driving it yesterday, and I turned a corner, it did it again, and it started to make this sound, like an electric saw cutting into wood.
I opened the trunk, and noticed when it's put into drive, the whole engine shifts.
How would I go about fixing this?
Kohburn
FierHo
Post by Kohburn »
depending on how much it is moving you could have worn out or torn engine and transmission mounts. if they are bad then IMO it is best to replace them all at once since one worn out mount can make new ones die pretty quickly.
not sure what the buzsaw noise would be unless there was an internal problem in the tranny or if the flywheel, a belt, or half shaft was hitting something during the turn. which can also be cause by worn out mounts.
you can get all new replacements from autozone or a similar parts store.
or you can get improved mounts that will last longer from rodneydickman.com
Kohburn wrote:depending on how much it is moving you could have worn out or torn engine and transmission mounts. if they are bad then IMO it is best to replace them all at once since one worn out mount can make new ones die pretty quickly.
if its an auto trans, check the fluid level
Yeah, auto or manual? Does engine RPM change? Does power delivery change, or is it just noise/vibration?
On my formula, torn transmission mounts allowed the engine to tip over far enough that the bolt through the engine side dogbone mount tapped dents into the strut tower on really hard left cornering.
p8ntman442
cant get enough of this site!
Post by p8ntman442 »
My broken rear tranny mount let the left axle contact the cradle. Tore the boot and made an awful mess.
