Archies Rockers
Driven Visions
Archies Rockers
Post by Driven Visions »
Has anyone here installed Archies rockers?
We are installing a set for a customer and I am worndering if I got a bad set. Having trouble with fitment.
Thanks
Blue Shift
Post by Blue Shift »
It would be my understanding that that would be SOP from him... :la:
I'm not in the least bit surprised... what problems are you having?
Chris-Nelson
Post by Chris-Nelson »
I am from MN so a friendly "donchaKnow" to you! :)
Anyways, I bought a set of knock-offs from a scam artist in FL years ago and there were some minor fitment issues with them and when I posted if anyone else had these same problems I remember getting 3 responses on fiero.com about how they bought the real ones from V8Archie himself and had spent up to an average of 5 hours just fixing the problems with it - fiberglassing, cutting, making them fit better, etc... So good luck finding a better set
Oreif
David Kopielski 847-301-2684
Post by Oreif »
hmm, I haven't bought any fiberglass parts from him so I can't comment. I have talked to others who have though and they had the same problems.
CincinnatiFiero
Post by CincinnatiFiero »
Winkie bought real ones, said he has issues, along with everyone else who bought them.
Darrelk
Post by Darrelk »
I've been building kit cars, doing body kits, and just about anything that was made of fiberglass for the last 37 years now. There are very few fiberglass craftsmen left here in the U.S. Add to that the current "state of the art" in fiberglass work... Most molds are getting older and show signs of flex which makes for innacurately fitting parts. Some piece are created in separate smaller molds then "flashed" (fancy name for glued with glass) together to form the larger part. Sandable gel coats are another problem. After mold release butter is applied guys hose this stuff on, some of it is picked up in the gel coat and poof! instant pinholes, craters, etc.
The last full sized kit truck I built had over 20 running feet of flash seams that I had to die grind open and re-resin and matt. One side of the the rear bed was 2 inches too wide and had to be relief cut and re-glassed. Pinholes??? I had to take a dental pick and push on every square inch of the body to open them up and fill them. It has been such a problem on most kits that I now use a sprayable polyester body filler which coats everything so I don't miss any stuff.
I saw a fiberglass hood at a local speed shop, $350. It had a diagonal warp in it, pinholes, and I saw a two cracks and a starred area in the gel coat. And you wonder why those rockers don't fit??? Sorry, for the rant but I just think most of this stuff is poorly made, no matter where it comes from.
FormulaGT
Post by FormulaGT »
It is not the person making the rockers. It is the molds themselves, they need to be replaced.
Trust me.
THE PUNISHER
Post by THE PUNISHER »
friend of mine bought a set directly from V8Archie... V8Archie swore up and down they fit with no issues and were basically bolt on.
Jeff ended up sending them back after a huge battle with V8Archie .. I saw them in person as I wanted to get a set
Absolute Junk.. No wonder the guy goes bankrupt on a yearly basis.
FormulaGT
Post by FormulaGT »
[quote="THE PUNISHER"]friend of mine bought a set directly from V8Archie... V8Archie swore up and down they fit with no issues and were basically bolt on.
Absolute Junk.. No wonder the guy goes bankrupt on a yearly basis.[/quote]
When was this? Must have been a few years ago. The quality of the glass and how it is laid is fine, as of up to mid 2006. Although the fitment has always been an issue, thats due to the molds. I dont think they were done correctly in the first place.
FGT
Post by FGT »
:confused:
'88 GT, 3800 SC II, IMSA/MC widebody combo, Choptop, Borla exhaust .
'88 Notchback, now parts car
Central Florida Fieros
FGT wrote:I had this issue too with the part that leans on the inner door frame. It had 1/2" + gap. I contacted V8A about it (2007), he never heard of the problem. I was thinking it might be due to my '88. Then I found out I was not the only one. He was very helpful and replace them for the Mad-Arch widebody rockers (@ extra cost). Since I got my Fiero w/ the widebody installed from V8A (April '08) I notice a gap of 1/4" to 1/8". I'm going to have to pay some one to fix them right. :(
Why not send it back to him and tell him to do it right at his expense of course. You paid a bunch of money. You deserve to have quality work done.
Demanding what someone can't give doesn't get you anything but frustrated.
FGT
Post by FGT »
:confused:
whipped
Post by whipped »
If he charges $10/hr, 47 hours sounds fair to me.... heh :thumbleft:
All I know is that if any of his/their/whomever does their work is like my fiberglass battery box, stay away! It was warped and wasn't cut straight... But I don't have a show car, so I don't care. Norm's stuff looks pretty good as far as quality, but he didn't sell just the battery box at last check.
FGT wrote:[
I'm not happy after paying aprox $17k in labor. His customer service skills are extreamly poor.
YOU will soon be labeled a troll and don't be surprised if you are banned soon. That is if you post the same thing on poopcocks as you do here.
Don't be afraid, just do it, if he does shitty work and not how you want it, then other potential customers need to know!!!!!!!!
p8ntman442
cant get enough of this site!
Post by p8ntman442 »
6 days to install 2 mirrors. WTF. 6 bolts and 8lbs of bondo is not hard to figure out.
p8ntman442
All your base of radius are belong to us!
and wtf is V8Archie doing with a caddy in his shop? a N* conversion. This should be commical. maybee the N* blew a head gasket and hes replacing it with a carbed 305 for his new daily driver.
Northstar?
The Dark Side of Will wrote:Northstar?
I beleive curly uses n-stars. Or at least one of those guys. Even they don't trust V8Archie with installing one of his kits because they know a sbc is crap. seriously, they aren't the type of guys that want a hole in their wheelwell for the waterpump.
