Where can I buy new GM electrical connectors?
I want to redo my harness, using all new connectors, and all new wires. Where can I buy the connectors with tails from? Like the common ones, TPS, IAC, CPS, etc?
Thanks!
Thanks!
I like NAPA myself, could give em a call to see if they carry them. Any of them should be able to order the connectors for you if they're not too lazy.
A lot of times if you ask for something and the desk guy says "we don't have it, sorry" it really means, "we don't stock it and I don't feel like placing the order."
There's always the FieroStore, but I think they're markup is a bit much.
Which connectors do you need specifically? I could see if we have them in stock tomorrow.
I'm not surprised, most of the parts guys don't know shit about cars, and aren't willing to help in the least.
I won't buy anything from the FieroStore anymore, they sell cheap shit.
I need, well, all of them for a 3.4 DOHC. If they are more than a couple bucks a pop, I think I'll pass since I need more of a "bulk" order. Thanks in advance for checking though!
CarQuest has weatherpack connectors.
The real deal is www.powerandsignal.com
They are Delphi's ONLY aftermarket distributor for harness products.
However, they only sell to licensed distributors.
You'll have to get in touch with one of their LTC (less than case) distributors to order what you want.
You'll need Delphi part numbers, too, as no one in that supply chain knows what a "3.4 TDC TPS connector" is.
All the motormite #'s are here:
https://www.dormanproducts.com/catalog/ ... x_bkup.htm
NAPA's Echlin line is awesome. Carquest has lots of stuff on the shelf. Both are a little pricey.
My weatherpack thread had lots of links too...
EDIT:aaron one of the links in my thread had connectors as low as $1.35 each, but that's just hollow. Pins and wires would have to be assembled to snap into them, but they had pins and insulators in bulk. A little more of a PITA, but much better than paying $12 per pigtail at carquest or NAPA.
EDIT again: P8ntman, you're the one who posted it. Here's their weatherpack page Sherwood.
They've got others on other pages too.
Also has the corresponding GM# on Sherwoods page.
Ok, I decided I'm going to keep using my stock connectors, as they are in good shape.
However, I do want to replace every wire with a new one. Anyone have links for automotive wire in every color imaginable?
Did you miss my post in the Parts & Materials library?
These guys have the connectors you are looking for:
www.eficonnection.com
I think if you call them they will sell individual parts.
Waytek Wire (www.waytek.com I think) has terminals for Metripack stuff. It's cheaper to just reuse the Metripack connector cases and repin them with new terminals from Waytek.
