I decided to go crazy on my LX9 intake manifold, figured I would post up a few pics. hopefully I'll be able to get it welded up later this week.
my 3500 intake.
my 3500 intake.
Re: my 3500 intake.
Done.
got air?
got air?
Re: my 3500 intake.
Looks like it can get you some air.
What throttle is that? Stock?
Has the throttle neck been verified to be a restriction in that UIM the way it is in the Fiero UIM? If so, is the stock throttle NOT a restriction for the power you want to run?
Re: my 3500 intake.
it's an LS1 throttle body, the flange was supposed to be an adapter plate for a 3900 manifold, but the 3500 TB uses the same pattern. A couple of guys are running the N*/LS1 TB, but the neck right behind the TB narrows to about 65mm (stock throttle size) the way I saw it, there was no point in using the LS1 throttle if it was just going to neck down right behind it, so I made it bigger.
there will be no restriction...
