Would it be "Accepted" if I used a g-meter for a s
If i did a 100ft skidpad g test would you guys accept that as "good enough" or would I need to pull a Cali and make it up but say it was on a "GM test track"
If I use an Apexi RSM or the like im sure that would be cool. I could video it also.
I just want to see if Cali's 1.17g is even doable. or better yet, beatable.
Resident Import Elitist
1991 Skyline GTR
(OO\ SKYLINE /OO)
1991 Skyline GTR
(OO\ SKYLINE /OO)
A 1.17g is not possible by a Fiero. Period. Stock, modified, tube chassis, roll bar, whatever. Not possible. In fact, a 1.17g is not possible by any production car. I shouldn't say not possible, but not by a factory stock car. Not a Vette, not a Porsche, not a fucking Lotus. I would venture to say there are some cars that could do it, but these are the 600lb race cars built solely for the purpose of racing. ie the custom built race cars with laser welded tube chassis out of magnesium. I would like to see a Formula 1 car's g-rating though, I'd say it is up around 1.1-1.3.
VERY VERY few cars can even break a 1.00. The actual testing procedure is done around a 200ft circle. The car takes a number of laps, and is timed and from there they use mathematics to figure out its G-rating with respect to the individual lap time.
Enough. Using the standard testing procedures, I do not think it is possible on a Fiero frame with a Fiero body. I contradict myself here, by tube chassis I meant modified frame. Of course a purpose-built tube chassis race car with a Fiero body might be able to do it, but not with anything even remotely resembling a Fiero's structure.eHoward wrote:How much would you like to wager?
aaron wrote:A 1.17g is not possible by a Fiero. Period. Stock, modified, tube chassis, roll bar, whatever.
Not with the standard of testing that all car manufacturer's and testers use. Maybe at the high speed turns they take, but not around a 200ft circle. They simply won't go fast enough to create enough downforce to get that high of readings. Maybe around a long turn at 200+ MPH I wouldn't doubt thatcrzyone wrote:Try around 3.5-4Gs aaron.aaron wrote: I would like to see a Formula 1 car's g-rating though, I'd say it is up around 1.1-1.3.
Its called downforce, read up on it.
Please admit you are wrong and that you learned something.
The front and rear wings on F1 cars are setup for what they want to run. With a slow track they add larger wings to improve downforce.
Around a 200ft skidpad they will pull much higher than 1G aaron.. Stop being a know-it-all.
I don't know what they'd pull, I'd expect it to be around 1.3g, but I wouldn't be surprised to see it as high as 2. But a 200 diameter curcle, there is no way that car ill get to speeds high enough to where they can reach G's any higher, or significant amoutns of downforce. The speed simply isn't high enough. That is one of the reasons for such a small circle, is so that in the testing procedure the amount of downforce created isn't a large influence and it comes downt o suspenion and tires.crzyone wrote: Around a 200ft skidpad they will pull much higher than 1G aaron.. Stop being a know-it-all.
g meter measures peak. You would need to get something that likes gievs an average or something. Basically like the same equipment the mags use.
I used a g tech to test my 95k mile suspension 85Gt and I hit .95. It was a peak number. Turn the wheel sharp and for that split second before you lose traction you hit a high number. I guess I should say I did that though on stock tires with just a rear bar?
If its going to be something that measures like the mags then go for it. If not why waste the money.
Re: Would it be "Accepted" if I used a g-meter for
Since you're canadian, do you mean 100' radius, or diameter? Diameter would be too small...donk_316 wrote:If i did a 100ft skidpad g test would you guys accept that as "good enough" or would I need to pull a Cali and make it up but say it was on a "GM test track"
My money is betting with Howard.aaron wrote:Enough. Using the standard testing procedures, I do not think it is possible on a Fiero frame with a Fiero body. I contradict myself here, by tube chassis I meant modified frame. Of course a purpose-built tube chassis race car with a Fiero body might be able to do it, but not with anything even remotely resembling a Fiero's structure.eHoward wrote:How much would you like to wager?
After the '96 Solo II Nationals, Road & Track hosted a skidpad challenge. The results used to be on the internet but I couldn't find them. Somebody else probably can.
Anyway, there were a number of stock class autocross cars that pulled over 1G on the skidpad. Stock class Neons and Miatas were in the 1.03 - 1.05 G range, if I remember correctly. The only things that affect handling that can be changed in SCCA Solo II Stock class are tires (hint, hint), shocks, front sway bar, and alignment. Of course all these cars were on autocross tires. I think the BFG Comp T/A R1 was the hot tire at the time.
I think with some competent suspension tuning and good tires, an '88 Fiero should be able to hit 1.17G.
I can see transient figures in a fiero that go a little over 1G, but not much more. I mean, come on--if I remember right Schumacher rarely hits 2.0 in the Ferrari F1 car.
3+ g? I don't think so.
CKM's car? .89 max. If that. Stock suspension with gut springs and bigger tires/rims doesn't get you that much out of .85 gs.
