Page 1 of 6
Aluminum Radiator question.
Posted: Sun Feb 19, 2006 2:28 pm
by Fast88Fiero
Ok, so the time has come to upgrade the radiator in the 88. I still have the factory radiator in the car and the car was a 4 cyl. Now that I have an engine swap I figured I should get a new radiator. I'm not sure of the size of the stock radiaotr, but I remembered reading that this radiator would work.
http://store.summitracing.com/default.a ... search.asp
Anybody know for sure if this will work? Any better options out there?
Thanks!
Posted: Sun Feb 19, 2006 3:37 pm
by whipped
The original fiero radiator is 24.5" x 16.5" overall. 1 5/8" thick core. In *theory* it should drop right in, you might have to massage the brackets a bit. It's the closest thing I've found to a drop in alumnium replacement radiator...
However, one thing I noticed when I first saw that radiator, is that it is only a single row... Now it will easily out-cool the stock radiator. Actually the corvette radiator is about the same size, and those are good for 400+hp. I've been running the stock radiator for a while now with ~330hp, with only limited problems with the temp creeping up on really hot days.
I really like the prices/dual rows of the trukool radiators, but damn, they're 19" tall!
http://www.speedwaymotors.com/xq/aspx/p ... roduct.htm
Posted: Sun Feb 19, 2006 3:53 pm
by Fast88Fiero
I'm not having any major cooling issues with my stock radiator either, just wanted to upgrade it a bit. I dont want to do any major work to get the radiator to fit so I think I'm going to order the radiator from my post above. It should be a good improvment over stock. :thumbleft:
Posted: Sun Feb 19, 2006 5:30 pm
Please when you get it do a full write up with pics of the install. I would also like to upgrade mine, but since I have the time, I may as well sit back and learn from others.
Posted: Mon Feb 20, 2006 2:13 am
Fast88Fiero, could you weigh the factory Fiero radiator and the aluminum radiator if/when you get it? I'm interested in this for weigh reduction purposes.. the 4cyl radiator is currently cooling my 3.4 DOHC fine, even at the track.
Posted: Mon Feb 20, 2006 2:50 am
by Fast88Fiero
Series8217 wrote:Fast88Fiero, could you weigh the factory Fiero radiator and the aluminum radiator if/when you get it? I'm interested in this for weigh reduction purposes.. the 4cyl radiator is currently cooling my 3.4 DOHC fine, even at the track.
Sure will! :thumbleft: It will probably be a few weeks before I install it. I ordered it today but want to take the car to work to install it. If this damn ice/snow/cold weather would go away I'd be driving my car.... :angry:
Posted: Mon Feb 20, 2006 10:13 am
by whipped
I think it'll probably be heavier. Doesn't have the plastic end tanks, and the core is like 1/2" thicker. Probably weighs 1/5 of what an archee brass 4 core does though,
Posted: Mon Feb 20, 2006 10:34 am
whipped wrote:I think it'll probably be heavier. Doesn't have the plastic end tanks, and the core is like 1/2" thicker. Probably weighs 1/5 of what an archee brass 4 core does though,
But you need the better cooilng in the V8Archie kit because of all the torque.
Posted: Wed Feb 22, 2006 8:39 am
by Fast88Fiero
I got the aluminum radiator yesterday and it weigh's 7lbs. I'm installing a stock radiator in a 86GT at work today, I'll be sure to weigh it.
Posted: Wed Feb 22, 2006 9:03 am
Awesome!
Be sure to take a lot of pics when you install it (The alum one..)
Posted: Wed Feb 22, 2006 1:07 pm
by Fast88Fiero
Just got the factory reman radiator for the 86GT. It weights 9.75lbs on our shipping scale at work. So the aluminum radiator is 2.75lbs lighter.
James
Posted: Wed Feb 22, 2006 1:34 pm
by whipped
wow, that's surprising!
Posted: Wed Feb 22, 2006 1:37 pm
by Kohburn
eh not really - i got a replacement radiator for my dodge daota recently and the new one was twice as thick but alminum and weighed less..
Posted: Wed Feb 22, 2006 8:51 pm
Fast88Fiero wrote:Just got the factory reman radiator for the 86GT. It weights 9.75lbs on our shipping scale at work. So the aluminum radiator is 2.75lbs lighter.
James
Thanks for the info!
I had no idea our radiators were so light already! Does the aluminum radiator have the same coolant capacity?
Posted: Wed Feb 22, 2006 9:26 pm
by Fast88Fiero
James
I think the aluminum radiator holds a little more coolant because it's slightly larger. Probably the extra weight in coolant will equal the two out.
Posted: Mon Feb 27, 2006 5:06 pm
by whipped
So is it installed yet? You've had the weekend... :la:
Posted: Mon Feb 27, 2006 9:10 pm
by Fast88Fiero
LOL. Hell no. Weather here sucks ass. It's too damn cold. If it ever warms up I'll drive the car to work and put it in. :thumbleft:
Posted: Mon Feb 27, 2006 9:56 pm
by S8n
Fast88Fiero wrote:LOL. Hell no. Weather here sucks ass. It's too damn cold. If it ever warms up I'll drive the car to work and put it in. :thumbleft:
I hear you about the weather....high here today was only 68!! I was freezing my ass off.
Posted: Mon Feb 27, 2006 10:49 pm
by Fast88Fiero
Only 68.....you suck! It was 25 here today. It's about 12 out right now. I'm ready for summer!!
I'll be sure to take pictures of the install when I get to it and post them up. :thumbleft:
Posted: Mon Feb 27, 2006 10:56 pm
by S8n
I remember cold days. I used to live in Wyoming. :puke: BTW, do you have A/C on the car? I'm really interested on how this rad turns out!
