Sweeeeet 6x6
4 trailing arms, 2 leading arms - left right braking for stearing - super simple
http://www.cmu.edu/cmnews/extra/060428_crusher.html
its a hybrid - has an electric motor in each wheel hub.. top speed is 26mph
may as well be using pack mules :la:
for the money they spend on these projects i'm unimpressed
now if they can network them together so that a remote command center can control them on a battlefield like a game of Command&Conquer then i might concider being impressed :thumbleft:
unimpressed because there is nothing special about it aside from being unmanned.. and applying hybrid tech to simplify the drivetraincrzyone wrote:The thing can climb a 4-5 foot vertical wall and you are unimpressed?Kohburn wrote: for the money they spend on these projects i'm unimpressed
That thing is badass. 26mph is plenty fast for a vehical with those capabilities.
i've seen rockcrawlers climb 8-10 foot walls with the help of a few straps to avoid flipping backwards.. that was cool but they also didn't use millions of dollars in funding
i grew up next to the test track that APG used off base to test the tanks and humvies.. i'm familiar with how those perform --The Dark Side of Will wrote:Could they climb the walls at 26 mph? You saw how fast that thing got over pretty much anything.
and it didn't go up the wall at 26mph it dead stopped at the wall till it was able to get the tread to bite the edge and climb over, same as all the offroaders in jeep wranglers
for the height of the wall... what is the actual size of that thing? unless the wheels are 8' tall that wall wasn't 5'
going from memory from yesterday would have to watch it again..The Dark Side of Will wrote:Are you watching the same video the rest of us are? That concret barrier it went straight up was taller than the front tires, which probably ARE 5 feet in diameter.
still unimpressed for the $,$$$,$$$.$$$
no doubt the top speed is limited by the motors they used in the wheels - most likely setup for maximum torque but limited speed.. a simply planitary gearset in each wheel could fix all that
