Head Compatibility
Posted: Fri Aug 18, 2006 3:21 pm
by wolken
OK I changed a head on my 84 Fiero because I thought it was warped, car ran fine before just overheated all the damned time.
Anyway I put a 86 head on an 84 motor (L4). Anyone see a problem with this? After bolting everything down and hooking it all back up it doesnt so much run right anymore any ideas? Is the head not compatible? I can get it to start and it sounds roughly like a dirtbike. It wont stay running.
Thanks
Wolken
Posted: Fri Aug 18, 2006 5:06 pm
by Mach10
Did you check the head over before putting it in?
Did you lash the valves properly?
First thing I'd do is check your timing (because it's easy to goof up), then check your compression. :thumbleft:
Posted: Fri Aug 18, 2006 11:29 pm
by rube
Yeah, check the valve lash. Did that wrong on my 3.4. Is it smoking?
Posted: Sun Aug 20, 2006 1:49 pm
by wolken
there is no valve lash on an L4, you just torque them to spec.
