EGR tube gaskets for 2p8
Posted: Sat Aug 26, 2006 10:19 am
I need the gaskets that seal the EGR tube to the manifold & EGR valve. CarQuest doesn't have them listed as such, although they may be in the EGR valve gasket set.
Anybody know where I could get these? Fierostore?
Posted: Sat Aug 26, 2006 10:35 am
I do know they come in the intake gasket kit from felpro. Its like $25 but kind of pricey if you only need the egr stuff. I might have some laying around. If so I can slap a stamp on an envelope.
Posted: Sat Aug 26, 2006 10:57 am
If you have a couple, that would be good.
The Fierostore has them for $3.50 each.
I'm going to check Advance & Autozone today.
Posted: Sat Aug 26, 2006 1:15 pm
by rube
You could just get some copper flashing and cut your own.
Posted: Sat Aug 26, 2006 1:23 pm
Car's not urgent. I'll save the creativity for engine swaps.
Posted: Sun Aug 27, 2006 1:37 am
2p8? Time for an engine swap.
Posted: Sun Aug 27, 2006 9:42 am
Looking at 3.0 TDC, but have to build the engine first and don't have pistons/rings yet.
Posted: Sun Aug 27, 2006 10:41 am
don't know if the 2.8 egr gaskets will work. Not sure if they are the same as the TDC gaskets. If thats what you need them for is a TDC then I prob can't help ya.
Posted: Sun Aug 27, 2006 11:19 am
No, need them for 2p8.
Posted: Sun Aug 27, 2006 12:15 pm
by MNFatz
Summit stocks exhaust gasket material sheets. Something like $5 for a sheet 12 by 12 inch square.
Of course you'll have to find something else to buy--the handling charge will be more than the purchase.
edit: Here's the part number: PHP-68006. unfortunately it looks like they're out of stock until 9/15.
Posted: Sun Aug 27, 2006 12:27 pm
ok then yea I have a set for the 2.8 The metal one for down at the valve, and a paper one for the intake mani. Felpro peices
Posted: Mon Aug 28, 2006 1:18 am
by rube
Copper sheet, a pair of snips and a couple of hole punches is creative? OK.
