2.5L Pushrods
wolken
2.5L Pushrods
Post by wolken »
Did the length of the pushrods change from 84 to 86? I just installed an 86 head on my 84 block head and they click really bad so I would guess yes. Anyone have any information on that?
Thanks
Wolken
I beleive they are the same because I don't think they went to a roller cam untill 87 year.
Did you even bother to check to see if the lengths were the same when you swapped the heads?
wolken
couldnt
Post by wolken »
I didnt have the rods from the other head so that wasnt an option. I just assume that they were different because you dont adjust the lash on those valves.
Kohburn
FierHo
Post by Kohburn »
easy way would be to see if they are the same part number online at gmpartsdirect
wolken
Post by wolken »
Thanks that helped, the part number changed for that pushrod between 84 and 85
befarrer
Post by befarrer »
They changed to a roller cam in mid 85, or early 85.
