Page 1 of 2
Coil overs???
Posted: Mon Sep 18, 2006 10:59 pm
by product1620
What are the advantages of running coil overs as opposed to lowering springs, and regular shocks/struts; The only thing I can think of is adjustability and weight savings, but im gay and know jack shit about suspensions so, you suspension gurus please chime in! :thumbleft:
Posted: Tue Sep 19, 2006 1:30 am
by TurboGT
You can run larger rear tires.
You have a larger selection on spring rates and heights, and springs are cheeper.
If you have the equiptment (scales) you can balance you car out by adjusting each wheel. There are equations out there that tell you how to shift your weight (i.e. adjust your coil-over, or move shit around) so you get the balance you want.
Posted: Tue Sep 19, 2006 4:19 am
by Tha Driver
:salute:
sayonara
Posted: Tue Sep 19, 2006 4:25 am
I am using Coleman racing sleeves with QA-1 springs.
Posted: Tue Sep 19, 2006 12:01 pm
Same.
Cheapest sleeves/nuts I've found are from Coleman for $40/each.
Cheapest springs I've found are from Summit for $35/each.
Beyond that, it's just some cutting on your struts. Konis run abour $350/pair from
www.shox.com
Posted: Tue Sep 19, 2006 12:51 pm
by TurboGT
I am also running those
Here is a link to my swap and info I found
phpBB/viewtopic.php?t=2251&highlight=
Posted: Tue Sep 19, 2006 1:14 pm
by whipped
x4
with crappy kyb struts. Don't recommend them.
Posted: Tue Sep 19, 2006 1:57 pm
by Kohburn
whipped wrote:x4
still better than the stock struts that have 0 rebound damping
Posted: Tue Sep 19, 2006 2:35 pm
by whipped
true
Posted: Tue Sep 19, 2006 2:41 pm
by Kohburn
whipped wrote:true
I have a theory that those stock struts were a factor in the snap overstear with the back end popping up without damping effects.
of course i've never experienced that, only slid the back out in the rain
Posted: Tue Sep 19, 2006 3:17 pm
by whipped
I'm sure they would be good for a stock replacement w/stock springrate springs, but I think I have 300 or 350lb/in QA1's. So they work "ok"... I'm not bouncing down the road or anything...
Posted: Tue Sep 19, 2006 3:57 pm
by Kohburn
yeah stiffer springs NEED stiffer damping - so konis are the only way to go for performance and longevity
Posted: Tue Sep 19, 2006 7:54 pm
by Jinxmutt
Posted: Tue Sep 19, 2006 10:12 pm
by DOHC GT
I am glad this topic came up. I am about to put new konis in the rear. Can anyone tell me the outer diameter of the koni struts so I can get the closest fitting sleeves. Thanks.
Posted: Tue Sep 19, 2006 11:14 pm
Eh? My stock 88 struts and shocks have 0 compression damping and a boatload of rebound damping. I was surprised when I checked them after removal.
The KYBs I have now have both compression and rebound damping. It's hard to tell how much because of the gas preload.
Oh just a note, I ordered some 350 lb springs that I'll be using with my KYBs. Hopefully I'll have something to say about that (whether or not the KYBs have anywhere near enough damping) in the next week.
Posted: Tue Sep 19, 2006 11:49 pm
by MNFatz
I'm using the Held kit for the 88 cradle conversion as well.
I don't recommend them. They're using short springs that come out of their sockets when you jack up the car.
I'm using 350lb springs on the back with an aluminum headed V8.
Posted: Wed Sep 20, 2006 12:41 am
MNFatz wrote:I'm using the Held kit for the 88 cradle conversion as well.
I thought they cut the spring perches and put sleeves down toward the bottom for use of longer springs? Is that not the case? What's the free length of the springs they use?
Posted: Wed Sep 20, 2006 12:34 pm
by Jinxmutt
Series, the pictures I posted above are held kits. You can order the springs in your desired weight and length. One kit I ordered I chose 300, the other kit was 325, its all up to you.
Posted: Wed Sep 20, 2006 1:37 pm
Jinxmutt wrote:Series, the pictures I posted above are held kits.
The ones on the KYBs?
If the kit on the KYBs that Jinxmutt posted pictures of is the Held kit, thats identical to the Coleman racing sleeves. There isn't any other way to do it.
I found that 12" springs with 170lb/in rate gets me at the perfect ride height if they are just slightly snugged up against the seat. They don't fall out when jacking up the car... but that's barely stiffer than stock. If I used stiffer ones I would need some slack otherwise the car would sit too high since the springs compress less.
Posted: Wed Sep 20, 2006 6:32 pm
by Jinxmutt
yes, the KYB in the car are Held Kit. I specified the spring that I wanted. Did the same with the Koni Set.
These are a pic of the Koni in the car. I know the brake line is funky, I put it on the caliper wrong and didn't want to rebleed when it came to put the tire on and I realized I screwed up..
Its on the list of things to do this winter.
