Help with TPS activation switch install?
Posted: Fri Mar 30, 2007 6:24 pm
by goatnipples2002
Which wire do I connect to, the blue TPS signal wire or the gray 5+ volt? or better yet which one is the TPS output wire?
Posted: Fri Mar 30, 2007 6:51 pm
Where is your instruction manual?
Posted: Fri Mar 30, 2007 7:13 pm
by whipped
signal = output
Posted: Fri Mar 30, 2007 8:35 pm
by p8ntman442
I replyed to your thread on OE. Get a fucking manual (available online for free) and look up the wiring diagram. Its the TPS output wire so if you have a volt meter just check which one changes voltage with TPS location change.
People should need a liscense to work on their cars.
Posted: Fri Mar 30, 2007 11:29 pm
by Chris-Nelson
p8ntman442 wrote: People should need a liscense to work on their cars.
lol
Posted: Sat Mar 31, 2007 1:22 am
by cactus bastard
I lol'd a bit at that too.
Posted: Sat Mar 31, 2007 2:35 am
by goatnipples2002
I don't have volt meter and fuck you. Thanks for the help.
Posted: Sat Mar 31, 2007 10:10 am
by Dirty Sanchez
Grey wire is 5 volt reference, dark blue wire is TPS signal, and black is ground. You use the dark blue one. :thumbleft:
Posted: Sat Apr 07, 2007 1:11 am
goatnipples2002 wrote:I don't have volt meter and fuck you. Thanks for the help.
Fuck you too. Get a test light. Don't bitch at us because you don't have the right tools for the job.
