-$9000-
Well I've decided that I want to move onto something else. I've owned this Fiero for almost 12 years and have put tens of thousands of dollar into it over the years. I just feel like I need a change. I'm not all too big on going fast anymore and I am looking for something more road-course and autocross friendly.
The Basics:
-1988 Fiero GT
-Red exterior with beechwood interior
-Approx 122k miles (~10k miles since the 3800 swap)
-Automatic
-Power windows/mirrors/locks
-Cruise
-A/C
-No sunroof or T-tops and is spoiler-delete
-VIN#1G2PG119XJP213094
Powertrain Swap:
The swap was done by Ryan Gick (Darth Fiero on Old Europe) of Sinister Performance. www.gmtuners.com
Pages with my swap info:
http://www.gmtuners.com/Cus...iero/turbo/index.htm
Engine:
-3800 Series-2 L67 with approximately 70k miles.
-Home-ported L26 heads (bigger intake valves over the L36) with comp 105lb springs, and a competition valvejob.
-Home Ported camaro upper and lower intake manifolds
-1.84:1 roller rockers
-65lb injectors
-Denso Toyota Supra fuel pump
Turbo Setup:
-ZZP stainless front and rear powerlogs
-Custom Stainless Y-pipe
-BRAND NEW Master Power T61 Turbo w/ .68a/r T4 exhaust housing
-Synapse 40mm Wastegate
-Synapse BOV
-Custom aluminum charge-piping
-Custom air-air intercooler from ETS
-LS1 MAF
-Custom Cold-air induction
-3” exhaust into a magnaflow muffler
-TurboXS manual boost controller
-Silicone boost lines
Transmission:
-4t65e-HD performance built by Dave of Triple Edge Performance
-Custom Stall converter
-Upgraded clutchpacks
-Hardened input shaft
-Heavy duty transmission cooler
-7/8" chain and 3.29 gearset
Misc:
-NGK AFX wideband gauge
-Powdercoated valvecovers, fuel rails, intake manifolds, and turbo
-Header wrap from manifolds to muffler
-Turbo blanket
Suspension/Tires:
-Poly bushings all-around.
-Fierostore lowering springs with Koni red adjustable shocks in the front
-Held Motorsports coilovers with KYB struts and 300# springs in the rear
-Front balljoints and tie-rods have been replaced between 70-85k miles
-Wheels are 5Zigen Fn01r-c’s. 17x7 front and 17x8 in the rear.
-Tires are Falken Azenis RT615’s (225/45/17) in the front and Nitto 555 Drag Radials (245/45/17) in the rear
Brakes:
-Braided stainless hoses
-West Coast Fiero 12” corvette caliper brackets
-Baer Eradispeed 2-piece rotors in the front and regular C4 vette rotors in the rear
-Satisfied-pro ceramic pads
-Stock calipers painted red
Interior:
-Recaro seats with custom seat brackets
-B-quiet brown bread sound deadening throughout
-Black headliner
-Black carpet
-Black ‘Fiero’ embroidered floormats
-4” Pioneer speakers in the front with homemade mounting brackets
-4x6 Blaupunkt speakers in the rear
-Pioneer DEH-P9800 headunit with Ipod control
-Aeroforce scanguage and Autometer boost gauge mounted in Autometer carbon fiber cups
-Beretta shiftknob
-New center console skeleton with no broken holes
-Momo D-shape steering wheel
Exterior:
-New outer dew-wipes
-Powdercoated engine grilles-gloss black
-New tail-light lenses
The good:
-This car is professionally built and has been maintained very well. This car drives very nice, and will get ~26mpg in regular driving yet is faster than 95% of the street cars out there. With the sound deadening, it is not hard on the ears on long drives, and still has all the creature comforts like power-options, cruise, a/c, and a full-trunk.
-It’s FAST, and it’s reliable. Since the 3800-swap, I have had ~30 ¼ miles passes (around 10 passes on the current setup) and have not had a single problem. You can take this car to the track and run high 11’s right off the street. Throw in some 100-octane, turn up the boost a bit, and lower the tire pressure, and it’s a low 11-second car.
The bad/issues:
Powertrain:
- None that I can think of now that I put a new turbo on
Suspension/Tires:
-The front bushings squeak. They have been in the car for 50k miles and 10 years. I’m sure they need to be greased up.
-Due to traction issues, I run drag radials on the rear. This results in great straight-line traction, but makes it a bit soft in cornering. Plus drag radials don’t exactly have a long tread life. They still have quite a bit of tread-depth, but I’m not sure how long it will last.
Interior:
-Although the carpet is new, I did a crappy job measuring in some spots and the fit is far from perfect.
-There is some exposed wire for the wideband sensor. It is a Function-over-Form interior.
-The passenger-side Recaro seat has a small cigarette burn in it.
-Some of the carpet material on the lower doors has some ripping and fraying.
Exterior:
-The paint doesn't have any clearcoat peeling, but it's not in great shape. There is a lot of small nicks and scratches. The front and rear bumpers were repainted 2-years ago, but the front has a large amount of stone chips in it.
-The quarter-windows are original and have some of the usual cracking and delaminaing in them.
Misc:
-The car was in an accident at some point before I owned it. I believe it was hit in the right front. It causes no driveability issues.
Overall, I would give the car a 7 out of 10 in it's current condition. I have no issues with using it as a daily driver and have used it as a commuter on a pretty regular basis over the past year. I would not hesitate to drive cross-country in it. I have described virtually every little issue I could think of because I try to be as honest as possible.
I should also add that along with the car, I have these parts available if the new-owner would want them:
-A spare set of axles (direct swap)
-AusFiero Stage-2 scoops
-A full spare '88 rear cradle with all the suspension and brake bits
-Spare brake calipers and other various Fiero stuff
-The original seats (dirty, but no rips or tears) and carpet
Additional pictures can be found in my photobucket album here: http://s105.photobucket.com...ursedx/Fiero%20Sale/
http://www.youtube.com/watch?v=4tc6Tln6l9I
http://www.youtube.com/watch?v=vyYbAx9AyBU
FS: '88 Fiero w/ 3800 Turbo swap. Professionally built.
Re: FS: '88 Fiero w/ 3800 Turbo swap. Professionally built.
I've had this on .nl for awhile and now that I have it running, I am trying to really push this to sell. I am pretty much only keeping it on Fiero boards for now as I would really like to have it go to an enthusiast.
Good luck with the sale, hopefully you can find a suitable buyer.
Always loved this car.
Absolutely adore this car. Though I won't be your buyer, how much are you looking for it?
On the other hand, that 1/4mi really shows the Fiero's strengths. The Corvette runs almost a full second slower, but runs 1mph faster at the end. That Fiero must really launch. Or the douche driving the Vette is like most douches driving Vettes, and never actually drive.
Aaron wrote:Absolutely adore this car. Though I won't be your buyer, how much are you looking for it?
Thanks, I'm looking to get $9000 for it (It's listed right at the top.)
And yes, although the Fiero does lauch pretty good, that run was only like a 1.8860ft. The guy in the vette was a typical vette douche. We ran two more times that day with pretty much the same result.
