for the most part, I work on my car alone, and some jobs are a bit more difficult to do alone, like bleeding the brakes, or a clutch. I bought one of these:
https://www.brakebleeder.com/products/b ... /2104-bot/
I used it to bleed the clutch yesterday when I installed the clutch line, it made the job easy. I was able to get it bled and flushed by myself in a matter of minutes. I think it worked way better than a "Mighty Vac" as well, but I did use a mighty vac to remove fluid from the reservoir as a pushed fluid through the system. your results may vary, but I thought I would share.
it's also worth noting that this can also function as a vacuum pump too.
brake/clutch bleeding
