Made another video for this next question about my fuel injector wire harness. I had to remove it all to install the new intake manifold, and now that it is all back together I want to make sure that I have it all installed correctly.
Here's the video:
http://videos.streetfire.net/video/12f8 ... 141485.htm
Fuel Injector wires questions - Video
with how old that harness is, it should be easy to identify which connector goes to which fuel injectors. Meaning, the harness is so old, the connectors when laying the harness out, should sit itself in the proper orientation of how the injectors go on.
However I don't think it matters all too much if you get them backwards because its a batch fire system.
Just try and get the injector clips for the odds and evens on the same side if nothing else.
Did you use teflon paste when installing those pipe plugs in the runners or some other type of sealent?
I agree. Does the 2.8 actually fire all 6 at the same time anyways? I know the 3.4 fires all 6 at the same time. If so, then it won't matter at all which goes to which, just make sure they fit easy.Shaun41178(2) wrote: However I don't think it matters all too much if you get them backwards because its a batch fire system.
I think it's three and three, odds and evens.Aaron wrote: I agree. Does the 2.8 actually fire all 6 at the same time anyways? I know the 3.4 fires all 6 at the same time. If so, then it won't matter at all which goes to which, just make sure they fit easy.
http://www.lordshadowstar.com
