This thread will remain for installing a Tilton clutch: viewtopic.php?f=3&t=3376
I recently bought this from ALLTRBO:
As you can see from the photo of the back, the flywheel has 141 teeth. I haven't figured out what P/N it is, though. I *DO* know it's one of the PN's they've offered over the years that bolts up to the Super Duty 4/Iron Puke and works with the Muncie transmission.
You can also see from the photos of the top that it's been used with the wrong throw out bearing, which has damaged the diaphragm spring fingers.
I had it on the surface plate because I was using some fancy QC gear to measure the height of various features on the clutch.
The tips of the diaphragm spring screws are 2.377" above the surface plate.
The flywheel friction surface is 0.764" above the surface plate.
2.377 - 0.764 = 1.613"
Per this post: viewtopic.php?p=50199#p50199
(The drawing that post links is now here: http://tiltonracing.com/wp-content/uplo ... 1-2-pl.pdf
*BUT* the drawing has been updated to reflect Tilton's current practice of using flat head screws installed from the outside to hold the diaphragm spring pivot to the pressure plate cover, as opposed to their former habit of installing conventional screws from the inside).
The depth of the 282 bellhousing is 2.425 over the output shaft bearing boss. This means that the QM unit would *BOLT RIGHT IN*. Horry Sheet! Although... not entirely unexpected. It is made for the Muncie application, after all.
Also per the above, the tips of the Tilton diaphragm spring screws are (were) 1.98" above the friction surface. Compared to the corresponding value of 1.613 for the QM, the Tilton was almost 3/8" taller in the same screw configuration! Again Horry Sheet!
The height of the NEW Tilton units is 1.706 above the friction surface with the flat head screws. The new Tiltons are STILL 0.093" *TALLER* than the QM's. Still Horry Sheet.
Flipping the diaphragm spring screws on the QM drops the height of the heads down to 2.245, *BUT*, the top surface of the pressure plate is 2.337", so that's as shallow as the clutch gets. Still PLENTY of clearance, though.
QM's pressure plate cover is stamped steel, while Tilton's PP cover is either cast or billet aluminum. That explains some of the difference in thickness. Fundamentally the QM is just packaged that much better. I am officially impressed.
The QM flywheel 506630 is still listed on their website, so I might even be able to order one. Their main tech guy sent me a (surprisingly) detailed drawing of it. I need to tweak the forum settings to allow .pdf attachments before I can upload it here. The crank flange mating surface on that part is too small for a Northstar (or LS) crank flange, so I wouldn't be able to plug & redrill it. QM's min run size is either 5 or 10, so I may be able to redline their drawing and have some parts made *WITHOUT* a crank bolt circle. That way one could be drilled for a Northstar or LS4 or LLT or even, God forbid, a 4.9.
Also, the part pictured above has an impressive number of speed holes, but the drawing does NOT show speed holes. That's one of the reasons I'm not exactly sure which part I have. The PN is not included with the part mark either (WTF?!?) The spec thickness per the drawing is 0.760; mine being at 0.764 means that it's original and has never been resurfaced.
Plan B is still to roll my own. That's even easier with the QM's better packaging.
Here's a quote about QM PN's from the Tilton thread:
The Dark Side of Will wrote: ↑Thu Nov 20, 2008 9:37 pm Quartermaster clutches:
http://www.racingclutches.com/~rclutch/ ... _Guide.pdf
506630 is listed as "FLYWHEEL PONTIAC FIERO 7.25". I guess that's what coinage has.
296626 and 296630 are listed in his application list as 2 disk clutches for 1 x 14 spline.
236626 is listed as "RELEASE BEARING FIERO L-4" (probably just means for the Muncie 4 speed).
296626 is still listed in the current application guide under "2 Disc 7.25 Pro-series clutch and flywheel" as "Clutch Pontiac L-4 7.25 1x14".
296630 isn't listed in the current app guide.
I wonder if any of these parts are actually still available.
Anybody know how the crank bolt patterns and flywheel pilot diameters compare from the Iron Duck to the 2.8?
