Or www.ti64.compmbrunelle wrote: ↑Sun Mar 27, 2022 11:31 am
If you want out-of-the-ordinary finishing, bling, or strength, that's when you go to ARP.
dude, we're building fiero's here...The Dark Side of Will wrote: ↑Sun Mar 27, 2022 12:07 pmOr www.ti64.compmbrunelle wrote: ↑Sun Mar 27, 2022 11:31 am
If you want out-of-the-ordinary finishing, bling, or strength, that's when you go to ARP.![]()
The less money you spend on the car, the more you can afford to go full retard with on parts for it.ericjon262 wrote: ↑Sun Mar 27, 2022 8:57 pmdude, we're building fiero's here...The Dark Side of Will wrote: ↑Sun Mar 27, 2022 12:07 pmOr www.ti64.compmbrunelle wrote: ↑Sun Mar 27, 2022 11:31 am
That bolt cost more than the heat shield! lol!pmbrunelle wrote: ↑Sun Mar 27, 2022 9:29 pm The less money you spend on the car, the more you can afford to go full retard with on parts for it.
This is an ARP bolt holding a tie-rod end heat shield to my cradle
They are listed as "beehive" on the website but they definitely aren't 'conical' anywhere....The Dark Side of Will wrote: ↑Fri Sep 16, 2022 3:47 pm Are they actually any lighter than stock, being that much larger?
Any reason (cost, I @$$ume) the new ones aren't tapered/beehived like the stock ones?
That happened to me YEARS ago when I was installing CHRF valvesprings on my Northstar.draven wrote: ↑Sat Sep 17, 2022 5:05 pm Welp..... i get to pull the head... or at least one of them....
While trying to replace the intake springs and retainers on the #6 cylinder I had to tap the keeper/spring with a rubber mallet and socket to dislodge the keepers. I lost all pressure in the cylinder as a piece of the GDI carbon buildup came off and lodged between the valve and valve seat as the keepers cam off and the valve slipped into the cylinder. buggar....
Don't see this as an opportunity to go ARP head studs as I will not be pushing this thing to crazy crazy hp >600hp, my goals are trackable 500-550hp at most. The LF3/LF4 community consensus is that they are not needed until one goes above 650rwhp... Furthermore, the F40 transmission seems to have a limit of ~700hp in the saab community as my turbo manifold builder builds some internal strengthening girdles for them but you have to pop the case to install them. That is unless having ARPs are better for other areas other than just max hp... i.e. longer term durability at extended moderate to moderate high boost levels.
Regardless this will be an opportunity to pull the DI injectors and have them cleaned as well or even upgrade the HPFP.
