EcoTec Fiero...It Has Begun
v6h.o.
Post by v6h.o. »
The Dark Side of Will wrote: Are those pics of the 5 speed? Dual layshaft? The gears look beefy.
Yup, 2001 5spd Getrag guts sitting on the holding fixture.
Colin 92 Sunbird GT 3200 Hybrid
13.99 @ 96.2 -fastest N/A v6jbody
2006 G6 GTP 3900 V6, 6spd coupe.
teamlseep13
Post by teamlseep13 »
The transmission is a stout piece, I have seen two 300whp Cavy's personally and heard of many more on forums.
bryson
Post by bryson »
I put 385wtq and 400whp through a 282 for awhile. When we took it apart, the transmission looked to be in really good shape. I didn't drive the car extremely hard, but I dropped it down into 3rd a few times pretty hard, and also a few times dropping down into 2nd and nailing it.
'87 BMW M6 / '88 BMW M5 / '90 Audi Coupe Quattro / '88 Fiero GT 2.3L Quad4 - 400whp; pump gas
TurboGT
Post by TurboGT »
I emailed Bates Engineering for some prices because I am still thinking about the swap.
Here is what I got priced, they seem very nice and offered to give me advice on my build if I wanted.
> esgv03000 adjustable cam gears $195 per pair
esgv0002 valve springs 208 set of 16***
> dsga0100 engine adapter 225 ea.
> Thanks for your time
> Marq
> *** Marq: Please note that with the dual drop in
spring
ESGV0002 you will need
valve spring seats ESGV0065 $ 50 per set (1 set needed)
valve stem seals ESGV0025 $ 50 per set (1 set needed)
and
retainers ESGV0105 $153. set of 16
These items are in stock and available for immediate shipment. All
major credit
cards are accepted. We would also be pleased to discuss your project
with you;
feel free to phone at 714-545-0159.
MIKE
Shane
Post by Shane »
[quote="TurboGT"]I know a guy that will make an adapter to mate the eco to our fiero trany for ~ $325. I dont know if he still makes them Ceticars@aol.com I dont know him personally, I found him when I was thinking about the swap.
[quote]
Bates Engineering that makes them for the gm drag race team sells them for $155.
TurboGT
Post by TurboGT »
That quote that I got above is form Bates engineering it is $225. The problem is that it dosnt come with the spacer for the flywheel, but that could easly be fabed up.
