Radiator wiring
Radiator wiring
Alright. I hit the road this weekend for a 3 hour trip. As soon as i hit a town and slowed to a stop at the light the car heated up pretty good. The fuse for the radiator fan was blown and as soon as i put another one in the fan turns 10 degrees and then burns out the fuse. I followed the wire up to the 'fire wall' and repaired any wire damage. After all that it still blows the fuse if i turn the key. Was wondering if there were some tips on what to look for at this point. Oh, ha ha and while fixing the wires I saw a few that had rotted out and patched them up. After I fixed the last one i saw my head lights flipped down. so now my headlight motors work.
Silver 85 GT-scratch that
Maroon and sliver 86 GT
Project Life
Project Life
so i should get a new relay first (cheaper) and go from there. wires are all tip top now and my last roomate decided he liked my tools alot when he skipped out so i don't have a voltage meter right now. I'll get the relay and see what happens from there.
Project Life
Project Life
I went out there on my lunch and followed the wires from the fan. one grounds out the other is spliced and goes directly into the fire wall. I'm guessing there used to be a relay between that? so if it's direct from the fuse to the fan and there's no splits in the wires then it's deffinetly the fan motor right?
Project Life
Project Life
If someone cut the relay out, it better be a BIG mofo fuse--and a slow-burn at that--because that fan motor will draw 50+ amps when starting. I seem to remember an Ogre article claiming 100amp peak draw (spike) from a dead stop.
I'd say someone fucked up. It might not actually blow a fuse when you're on the highway because the fan's spinning already, and doesn't draw as much.
well that's if the relay was in the same line from the fan to the fire wall. I'll check from the firewall when i get home. Oddly if thatwas the problem then I don't understand how it ran for the past month before the problem started. where does the relay normally sit for the fan?
Project Life
Project Life
alright there has deffinetly been some bypassed parts. The fan has 2 wires one that grounds out and the other that had been cut. It looks like it went to a bar with 2-3 other wires that pluged into something that's not there. It doesn't look like a bar that goes into a reylay because it's too long. The fan wire was spliced in with a smaller gauge brown wire with the white strip (power) and that goes directly to the fuse. I don't understand how it would have taken this long till it burnt out? It ran constantly when i turned the key and have a feeling it just over worked the motor untill it blew.
Project Life
Project Life
Crap... Ogre only has the diagram for his dual relay conversion... Which might actually help out seeing as you need to install the relays. Problem is, his schematic assumes that you already have the existing pinouts for the inputs.
http://home.comcast.net/~fierocave/fans.htm
I've got a decent set of full schematics at home. Trouble is my home PC took a dump on me last night, so I have no good way to get it to you before tuesday.
