Performance intake/exhaust options
There are several cam options for the 3400. However a new cam is out of your budget.
You can't run a roller cam in a 3.4 block though. Only the 3100/3400 blocks have provisions for the roller cams.
If you are using the 3.4 block, then use a crane 272 cam and matching springs lifters, pushrods, retainers, and lifters. It will have good "sound"
I'm not refering to cam lope, I mean a stout powerband, strong acceleration, etc. The 272 is pretty weak on the vacuum though and should, like you say, produce a neat sound.Shaun41178(2) wrote:There are several cam options for the 3400. However a new cam is out of your budget.
Will the 272 honestly get me decent results with a 3400 or am I shooting myself in the foot here?
Metallic Silver 1986 SE
I doubt I'd go smaller, seeing as I would LIKE to make 200WHP, but would be satisfied achieving 200 crank and slowly working my way up to 1HP/C.I.
So I should still be budgeting for some decent flat-tappet parts.
Would any of ARI's in-house cams rival the 272 for HP/dollar?
Their "phase 3 cam" is spec'd very, very closely to the 272 but there is a huge difference in price... "you get what you pay for" though.
A tough decision.
A tough decision.
A quick Google search came up with this site
http://www.fullthrottlev6.com/forums/sh ... hp?t=33452
It's a list of 60* v6 cams.
Stock 3.4
195/201 .390"/.410" 109°
Comp Cams
High Energy 240H (16-115-4)
192/200 .390"/.390" 108°
High Energy 252H (16-232-4)
206/206 .425"/.425" 110°
High Energy 260H (16-233-4)
212/212 .440"/.440" 110°
Crane Cams
PowerMax 2020 (254112)
198/204 .401"/.423" 104°
PowerMax 2030 (254122)
204/214 .423"/.423" 109°
H-260-2 (253901)
204/216 .427"/.454" 112°
H-272-2 (253941)
216/228 .454"/.480" 112°
Crower Cams
Mileage Compu-Pro Lv1 (03040)
182/192 .386"/.387" 114°
Mileage Beast Lv2 (03002)
194/202 .390"/.410" 109°
Baja Beast Lv3 (03015)
204/214 .422"/.444" 112°
Ultra Compu-Pro Lv4 (03043)
212/218 .435"/.449" 112°
Hi-Draulic Hauler Lv4 (03050)
226/234 .470"/.492" 108°
Edelbrock
Performer-Plus (3790)
204/214 .420"/.442" 112°
GM Performance Parts
12363220
204/216 .427"/.454" 108°
12364059
Lunati
High Efficiency (06312)
195/205 .405"/.427" 112°
Melling
Select Performance (MTC-5)
204/214 .420"/.443" 112°
Schneider
252-56H (02371)
194/204 .390"/.410" 110°
256H (02370)
204/204 .420"/.420" 110°
256-2H (02372)
204/214 .420"/.440" 112°
131H (02375)
208/208 .420"/.420" 110°
135H (02373)
218/218 .460"/.460" 110°
270-84H (02374)
214/224 .440"/.460" 112°
Solid or Solid Roller cams also available
60° 3100/3400/3500 FWD V6 Camshafts
(Roller Hydraulic Lifter, 1.6 Rocker)
Stock 3x00
197/197 .436"/.436" 112°
_________________________________
Check out the Crower Hydraulic Hauler.
It's got a bit longer duration than the 272, and seems to have the highest lift of any off-the-shelf hydraulic.
When I started hearing about people wiping out 272s in a few thousand miles (apparently not as widespread as I first thought) I was tempted to go with that one.
Go to http://www.crower.com/pdf/2-52.pdf
Scroll to page 18 or thereabouts.
They also recommend a spring kit that actually seems to be pretty straightforward. (Stock spring diameter, etc.) I'm not sure what you'd have to do to make it work with the aluminum heads, however.
To anyone who cares...
It's interesting that the stock iron head 3.4 has a "staggered" cam profile (exhaust has higher lift than intake), while the 3x00 seems to have a "square" profile.
Do the aluminum heads flow that much better in the exhaust ports, compared to the intakes?
Stock 3.4
Comp Cams
Crane Cams
H-260-2 (253901)
H-272-2 (253941)
Crower Cams
Edelbrock
12363220
12364059
Lunati
Melling
Schneider
252-56H (02371)
256H (02370)
256-2H (02372)
131H (02375)
135H (02373)
270-84H (02374)
Stock 3x00
BRDS
What I'm wondering is, since the 3x00 ships with the square profile, would it be beneficial to keep that square profile if the aluminum heads were going to be used, instead of going with the staggered profile such as the 272 or the Crower.
Just something to think about, before spending a bunch of money. I don't know anything about the aluminum heads, other than they're "better".
BRDS
Yea another alternative to the 272 was the Crane PowerMax F-228/3067-2-12 which looks like
duration@.050"-advertised duration-lift-lobe center
IN/EX|IN/EX|IN/EX|IN/EX
228/238| 290/300| .460/.480| 112/112
However, hiking the profile that much will probably only start to make the engine more unstreetable.
Matching the cam to the rest of the valvetrain is a good idea when considering lifespan, I guess I should be looking for the proper MATCH for the cam rather than the accepted benchmarks, IE LS6 valve springs etc.
