Aluminum Radiator question.
scrabblegod
Post by scrabblegod »
Does anyone know the difference in cooling capacity between a copper rad and an aluminum one of the same size.
I ask because my 350 powered MGB still has the stock rad and its cooling is not up to the task even running water wetter.
I can not go any taller than stock but I can go 2 inches wider and as thick as I want (up to 6 inches).
Gene
from google "thermal conductivity aluminum copper":
http://www.engineersedge.com/properties_of_metals.htm
Copper has 170% of the heat conductivity of aluminum... not sure how to translate that into heat exchanger efficiency, though.
You could have one made out of silver... that's got better heat conductivity than copper.
crzyone
JDM Power FTW
Post by crzyone »
Silver corrodes very easily and $$$ :thumbleft:
Copper is a better heat conductor but will corrode in the presence of sulphur compounds, as found in acid rain (SO2). Your nice copper color rad would be green in no time.
Aluminum is good enough I would think, also has good anti corrosion properties.
scrabblegod
Maybe I am mistaken, but when I say copper, I am talking about the stock radiator.
Is it not copper, or is it an alloy of some type?
What exactly are older rads made of?
whipped
Post by whipped »
stock radiator is aluminum with plastic end tanks
A rchie's 4 core that he supplies with his SBC swaps is copper... but it weighs a million pounds. That's why everyone is looking for an aluminum rad.
Kohburn
FierHo
Post by Kohburn »
I thought i remembered aluminum being a better thermal conductor - but maybe it was just conductivity/weight ratio
whipped
Post by whipped »
The Dark Side of Will wrote:That's why everyone is looking for an aluminum rad.
I thought it was because he was charging $350 + shipping? :scratch:
whipped
Post by whipped »
Oh, by the way... I may have found a decent radiator. Drop in 24x16x3, dual row 1" aluminum core... I'm requesting a quote, cross your fingers.
sweeet
whipped
Post by whipped »
Well, I was hoping for a price about $100 less....
$344 + 30 shipping, it has 1.375" in/out connections so it just might work with the stock hoses. (stock hoses are 1 5/16")
This is from rondavisradiators.com
Ouch...I think I'd stick with the Summit one, but I'm not running as much of teh hp as ya'll are.
Ask em if they'll do group buys :thumbleft:
scrabblegod
whipped wrote:stock radiator is aluminum with plastic end tanks
I was asking about the stock rad in my 67 MG.
Trying to find a way to cool it better (damn motor swaps).
Gene
whipped wrote:Well, I was hoping for a price about $100 less....
Ok... so the idea is that someone sends them a Fiero radiator and they duplicate it. Thereafter they have a job number that future Fiero customers can reference when ordering and the Fiero community just has to spread that job number around... right?
whipped
Post by whipped »
No, this is for a radiator they already make, part #1A-24163. I'm not sure if the 1.375" connections are the size they normally install however, you might need to specifically ask for those.
I gave it a cursory glance but didn't see anything specifically for the Fiero... this is a specifically made drop in part, right?
The Fiero radiator? It's aluminumnunumunuinimunum?
whipped
Post by whipped »
The Dark Side of Will wrote:I gave it a cursory glance but didn't see anything specifically for the Fiero... this is a specifically made drop in part, right?
Well, no, not exactly... It's ~1.5" thicker than the stock radiator, so it will take custom mounts, but it's the same x&y dimension as stock... So in other words, it doesn't require frame or hood trimming, or laying back the radiator at wierd angles... just fixing the mounts to accomodate the extra thickness. I don't know what that would entail, because I've never had to remove the radiator. I can't see it being too big of a deal.
whipped
Post by whipped »
What are you? British? :la:
Yeah, it is.
Ahh... well the radiator is cradled above and below in sheet metal pieces that are bent up for a radiator of that thickness. It has rubber isolators for a radiator of that thickness. The isolators seat on the joints between the core and the end tanks on the top and bottom edges. If you can keep the length of that joint the same as stock, and the spacing between them the same as stock, then a radiator will be a drop in swap.
Last edited by The Dark Side of Will on Tue Feb 28, 2006 4:52 pm, edited 1 time in total.
