Right now I’m in the process of porting a set of heads for this engine. I hope to have those finished up and on the car by the end of May. That should be the last mod that this engine will see N/A. I will dyno the car at that point in time and I'm hoping to make 260 HP. Keep in mind this engine has 110,000 miles on it. At that point the dyno will give me a nice base line for the engine N/A vs. Boosted. Before I boost I will definitely need to address the block.
Considering Matt Hawkin's car is pushing out 415 whp on a virtually stock block, and my goals being not much higher than that, I wouldn't be overly concerned with the strength of a good rebuilt engine with a few minor tweaks like he has, except for the fact that I tend to beat the shit out of my cars. I really don't want to see rods and pistons all over the road behind me.
What I'm thinking right now for the block would be ARP bolts all around, custom rods, hyper pistons, cryo treated crank, and using 3X00 mains.
Now about the mains, apparently the structural oil pan off the 3X00 which cross bolts into the mains does not bolt up to the existing bolt holes on the block. This can be remedied by either welding and redrilling the pan or redrilling the block. Personally, although the pan is aluminum I would rather weld and re-drill that than mess with the block. Luckily for me I know a great fabricator who could weld and drill those holes painlessly. The other option would be getting custom 4 bolt mains or just running the 3X00 mains without the structural pan because they are stouter anyhow. I could always do a custom girdle to work with the cross bolts but that would probably prove to be more trouble than it's worth.
I have a question about the pistons. Obviously forged are best but I'm not in the mood, now or in the near future, to drop close to 1000 dollars on a custom set. How well do hypereutectic pistons hold up to boost. I know Matt Hawkins is running these as well, and I know a lot of turbo factory cars have these as well, just seeking opinions. I know Sealed Power makes some hypereutectic pistons for this engine, and I think that's about as good as it's going to get for slugs without going completely custom.
So, now that I have questions about the block and my plans for the block laid out, obviously the turbo kit is next. As of right now because it's kind of staring me in the face and it definitely seems to be sized appropriately for the engine Kohburns turbo seems to be in the lead there. It'll save me a few bucks and should perform up to my expectations. Here's a link to the turbonetics website on the turbo:
http://www.turboneticsinc.com/products/ ... gory_id=89
As for exhaust with the turbo setup I think I'll need to run 3" into the muffler to reduce backpressure but run it in much the same fashion that I already have. For now because I'm running the stock manifold I'll be using a 2.25" crossover, which is stock DOHC, but Shorty headers and a different (I.E. larger) crossover will come later.
Now this is where things start to get hazy. Would an internal or external wastegate suit this application best? I have always heard that an external is best to avoid spiking and boost drop off, but perhaps there’s reasons to go internal as well. Perhaps I'm looking for a way to save a little money, or save room in the engine bay. Also I will be needing an intercooler, and due to the mid engined setup, I would think that liquid to air would be the best way to go about it. Trouble is that I don't know where to mount the damn thing. I wouldn't even know where to mount an air to air intercooler. Ideas anyone?!
In order to keep this engine alive with the turbo kit on it I will need some pretty good engine management. Besides that, I have had NOTHING but trouble with the fucking 94-95 Monte ecm with the manual tranny. I STILL have idle issues and stalling issues too. Basically, what I'm trying to say is that I want to get away, far, far away from that ecm. Right now, because of budget and compatibility, I'm thinking about converting to the TGP 7727 ecm. While yes, it will need much tuning, everything is realistically there. Boost maps, manual tranny functions, dis, and the same types of sensors. I don't have to worry about the EGR dilemma either since I am EGR-less. Again, open to suggestions on ecm's.
Right now that is about it. Really looking for ideas and input now. Sorry for the REALLY long post.
