computer for a Northstar install?
Identity Crisis
Post by Identity Crisis »
I'm picking up a Northstar this month and i am wondering what computer i should use with it?
SHould i just use the stock computer or should i try something like the 7730 or the holly pro commander, or etc etc.
Cheers
BUll
2014 Dodge Ram 1500 Sport
1992 Pontiac Grand Prix STE
1987 Pontiac Fiero GT
1986 Pontiac Fiero GT
THE PUNISHER
Re: computer for a Northstar install?
Post by THE PUNISHER »
as someone who had the commander 950 on my northstar, Don't do it.. no matter what alan @ chrfab says.. its complete crap...
Identity Crisis
THE PUNISHER wrote:as someone who had the commander 950 on my northstar, Don't do it.. no matter what alan @ chrfab says.. its complete crap...
OK, so no to holly. What are you running on yours?
I'm running the Shelby Aurora computer on my car. It's a MAF based system, so you have to use the '96+ cable throttle body. Any shop with HPTuners can tune it.
Contact Sinister Fiero on this forum.
NINJA EDIT: The above only works on '99 and older engines. If you have a Y2K or newer, you'll need something else.
Identity Crisis
Thanks! Where do i buy it from? This sinister fellow?
The Dark Side of Will wrote:Contact Sinister Fiero on this forum.
His username is Sinister Fiero. Send him a PM on this forum.
His website: http://www.gmtuners.com/
Identity Crisis
I have a 95 N*. So what i have gotten so far is dont use the stock computer, but rather use the 7730 or one from this sinister fellow.
Can some explain to me why a v6 cavalier computer is better then the stock one?
The stock OBDI computer is mostly untunable. I have a chip for it to run without automatic, but it's still a bit rich and stalls when you clutch on overrun.
The 7730 is tunable, even though it's batch fire. However, dyno shops that still deal with OBDI GM hardware are getting pretty hard to find.
The Shelby setup is OBDII, and any shop with HP tuners that can tune an LS1 can tune that computer.
Identity Crisis
I sent Ryan Gick (Sinister) an email.
Now I did a google search for Shelby Aurora computer but came up with nothing. Any links to this?
THanks
BULL
Identity Crisis wrote:I sent Ryan Gick (Sinister) an email.
THanks
BULL
The car it was in was called the Shelby Series 1. That may help with your search.
Identity Crisis
Thanks for the read. A very interesting car for sure.
So am I correct to assume that the factory computer is used and not some other computer in a N* swap then?
It uses the 09354896 PCM, which is the same one used in LS1 Corvettes, Camaros/Firebirds and trucks. It should cost no more than $50 from a junkyard.
EDIT: "It" = Shelby engine management.
Identity Crisis
The Dark Side of Will wrote:It uses the 09354896 PCM, which is the same one used in LS1 Corvettes, Camaros/Firebirds and trucks. It should cost no more than $50 from a junkyard.
Well I have the whole 95 STS so the cars computer will be there too.
So good I can use the factory 95 Computer then. Just getting mentally prepped for when I start to do the wiring. I did this too when I installed an L67 into an older 96 Grand Prix.
Not for the Shelby setup...
Identity Crisis
I am not doing a Shelby setup. Just installing a N* into my 87GT
Identity Crisis wrote:I am not doing a Shelby setup. Just installing a N* into my 87GT
You can't use the factory Cadillac computer with the Shelby code. You need an LS1 computer. The LS1 computer is the same as what was used in the Shelby.
He can use the OBDI computer... He can use the same chip I have.
Also, that computer may be more tunable now than it was a few years ago.
Identity Crisis
Ok now it is getting more clear.
In order to use the Shelby code which I can with my N* I need an LS1 Computer(ECM)
I can use the stock computer which should be OBD1, which will mean that I need to burn a chip and physically install it.
I can use the GM 7730 ECM if I wanted to.
Does all of this sound right?
Options:
1) LS1 computer with Shelby code
2) 7730 with modified $A1 code mask... I'm not sure where his final .bin is available, but member "whipped" on this forum set his up this way. The .bin file is the information which gets burned into the chip to install in the computer
3) Stock Cadillac computer (PN 16197429) with the manual transmission chip
4) Aftermarket management... sky's the limit
Also, what transmission are you using? With the 4T80E automatic, your options are more limited. IE, either the stock computer OR Sinister *MIGHT* be able to set up a custom calibration with the Shelby engine side and 4T80E transmission side.
Identity Crisis
I will be using the 4T80E.
