Banjo Bolt Bleeders on Seville Calipers
Banjo bolt bleeders seem common in the motorcycle world.
Banjo bolt + bleeder = These seem to be available in M10x1.0 and M10x1.25 threads (common in motorcycles).
I have looked for M10x1.5 (i.e. GM) banjo bolt bleeders, and they are unobtainium.
RaceTech Titanium makes a banjo bolt bleeder that's almost close enough:
https://racetechtitanium.com/product/ti ... eder-bolt/
I asked them about a custom M10x1.5x23 banjo bolt bleeder, and I was given this preliminary pricing:
4 pcs -> 125 USD /each
10 pcs -> 75 USD /each
20 pcs -> 40 USD /each
I would like four banjos (2 on my Fiero, 2 spares), so I find the price a bit expensive if I just get them for myself.
I was wondering if anyone else would want to hop in on this party.
Perhaps you have a brake caliper installed upside-down like I'm planning on doing: In this install, the brake cable passes below the CV joint, the banjo bolt is at the top, and the bleeder is at the bottom. So air bubbles cannot escape via the bleeder.
A banjo bolt bleeder could be used to remedy this situation.
I have a plan B to convert my calipers to M10x1.0, but I'd rather not do that.
Re: Group Buy Feeler: Banjo Bolt Bleeders
Doesn't seem too popular, not that I was expecting this idea to be...
So this is on my Zettner-style brake setup, and more specifically I have Kohburn-style 10° rotated brackets in the rear.
Finally the banjo hole isn't at the highest point of the caliper, so air could remain trapped in the bore.
I think this problem can be solved by cutting an inverted trench running from the high point to the banjo hole, but since I will have crossed the bridge of modifying the calipers, I might as well Heli-Coil them for M10x1.0 off-the-shelf banjo bolts.
I guess I have an ultimate objective of making the drum-in-hat work, so I can lose the Seville calipers, but that's for later.
I do not attempt to meet all objectives on the wishlist of a project in the first go; I seek to satisfy many objectives, and get something working on the car.
Like this I take bite-sized chunks of work, and I can test and get feedback on the rest of the system; feedback which could be useful for the next iteration.
Also I like to be able to use the car as a DD, sometimes.
Sounds like a great idea... But limited applicability. The upside down Seville calipers being the only app I know of, although it would be interesting to understand what the apps for 10x1.0 and 10x1.25 sizes are.
Ducati, Kawasaki and Magura (among others) are names that popped up when I was searching for this stuff. (1.0 and 1.25 pitch)pmbrunelle wrote: ↑Wed Dec 23, 2020 6:27 pm Banjo bolt bleeders seem common in the motorcycle world.
My understanding is that the banjo bleeder bolts are used for compact brake/clutch master or slave cylinders, where adding a separate bleeder screw would be bulky.
Polaris PN 1910886 is an M10x1.0 banjo bleeder. Length is unspecified, but can be estimated by counting pixels on pictures. I don't know what vehicle they use it on.
Generally these banjo bleeder bolts are 18-20 mm long; shorter than the 23 mm Fiero banjo bolt. I think this is because the motorcycle banjo fittings are less thick.
I ordered some M10x1.0x20 banjo bleeders:
Goodridge 992-31BNC
20 mm is about the longest available off the shelf. Not ideal in terms of thread engagement (at least with the Fiero banjo fitting), but I'm willing to roll with this, on my personal car.
So I worked on my calipers this weekend.
I began with cutting the Heli-Coil STI thread.
To align the drill press with the original hole axis, I screwed a long bolt (head cut off) into the banjo bolt thread. Then, I tightened the drill chuck onto the bolt shank, resulting in the caliper hanging from the chuck. Then, I adjusted the table to fix the caliper's position relative to the spindle.
Once the caliper was C-clamped to the table, I could loosen the drill chuck, and unscrew the headless bolt. Drilling+tapping could proceed.
For tapping I used a cone in the chuck to help guide the tap. I had one hand turning the wrench, while my other hand applied a slight downwards pressure on the quill.
I bought a 90° Dremel adapter. With this, I was able to cut a trench from the highest point of the caliper cavity towards the banjo bolt.
I like the fit up method, I'll have to remember that one.
Yeah, good thinking on how to clamp it down.
Did you try Old Europe for a group buy? Did I reply there?
I was lucky enough that the caliper had a flat face that was stable.ericjon262 wrote: ↑Mon Jan 25, 2021 12:21 am I like the fit up method, I'll have to remember that one.
My dad suggested that I could pour concrete around the caliper to cast it in place if I couldn't find a way to clamp it, but I didn't need to go that route.
No, I didn't really desire the M10x1.5 banjo bolts enough to offer them to a wider audience besides this smaller group.The Dark Side of Will wrote: ↑Mon Jan 25, 2021 7:13 pm Did you try Old Europe for a group buy? Did I reply there?
It was just less time/trouble/cost to go with the Heli-Coils; wasn't that bad at all.
This thread isn't really about a group buy anymore, it has evolved into modifying rear Seville calipers for use on my 84-87 Fiero.
I got the Heli-Coils installed and test-fitted the 20 mm long Goodridge banjo bleeder bolts.
The banjo bleeder bolt cannot penetrate too deeply into the caliper. If it does, then air could become trapped above the end face of the banjo bleeder bolt.
I torqued up a random old hose with new copper washers.
Penetration looks OK. I find this to be a satisfactory solution; I'm gonna roll with this.
I think that a stock-length (23 mm) banjo bleeder bolt would have penetrated too far into the calipers. That said, it may be possible to reduce the slope of the inverted trench to allow for the use of a 23 mm bolt.
Re: Banjo Bolt Bleeders on Seville Calipers
Solid fix!
Since it's only for bleeding purposes, you could also make that cut WAY smaller... think just the edge of a dremel cutoff wheel.pmbrunelle wrote: ↑Mon Feb 01, 2021 10:17 pm I think that a stock-length (23 mm) banjo bleeder bolt would have penetrated too far into the calipers. That said, it may be possible to reduce the slope of the inverted trench to allow for the use of a 23 mm bolt.
My initial plan was actually to use a cutoff disc, but with the angle required to perform that cut, the Dremel body (or 90° gearbox) ended up interfering with the caliper casting.
The integral bridge on this caliper was a PITA with regards to tool interference; it would be easier to do this type of modification on a caliper that is bolted together from inboard and outboard parts.
It was only with a 1/4" spherical carbide burr and 90° gearbox that I was able to get the cutter where it needed to be with reasonable control (freehand).
I also wanted the groove to be large enough that I could visually (and with a paper-clip probe) inspect my progress for a monotonic slope all the way to the banjo hole.
I agree that the material removal for bleeding purposes could be much reduced. The groove has its actual shape due to implementation and inspection reasons.
https://www.mcmaster.com/4370A5/
https://www.mcmaster.com/4344A74/
You said you used a 90 degree gearbox, though.
Just another reason to put a 5 axis mill next to your garage throne.
The gearbox I used looked pretty much like the 4344A74.
I was actually using a Mastercraft (Canadian Tire house brand) rotary tool, not a Dremel-brand tool.
It seems that they mostly share the same interface at the nose of the tool, so the attachments work just the same.
Those flex shafts are pretty handy, they really help with getting into tight places. I used to have one years ago.The Dark Side of Will wrote: ↑Thu Feb 04, 2021 8:25 am https://www.mcmaster.com/4370A5/
Good find.The Dark Side of Will wrote: ↑Sun May 01, 2022 8:32 pm Aside: '78-'80 Caddy Fleetwood rear calipers share the narrower mounting center of the '80-'85 Seville calipers used in the Fiero Zettner brake package. The Seville calipers have 2" pistons, while the Fleetwood calipers have 2.5" pistons, at least per the catalog. This means that the Fleetwood calipers could be used with the Camaro or S10 front calipers to give the Fiero the "square" brake setup that works well on it.
From the photo I could find, the bleeder is opposed to the parking brake cable mount, which could make these banjo bolt bleeder shenanigans unnecessary.
However, the Fleetwood calipers don't appear to be as readily available as the Seville calipers.
Thanks! I've had a "Zettner Upgrade Upgrade" thread in my head for a bit, but it hasn't been a high priority to post.
Yeah, the supply chain for the Fleetwood parts is a lot thinner than for the Seville parts.
LOL... I *thought* that the Motorhome disk conversion kit used the earlier wide mounting center calipers
It actually uses the later narrow mounting center calipers.
In looking for closely for calipers for the Motorhome, my dad found that the '78-'80 Fleetwood rear calipers I found are NOT HANDED.
It seemed sketch for GM to build them that way, but there's no technical reason not to.
I found this topic on CadillacForums: https://www.cadillacforums.com/threads/ ... cs.159416/
It has this photo:
As you can see, one caliper mounted forward and one caliper mounted aft.
It has this photo:
