Well, gonna give the Fiero a shot at the qtr mile tonight.
I guess we will see if the trans holds up.
15 psi of boost. 3900 stock.
Feel free to guess et and mph
I'll update later with results.
jdv
Re: Well, gonna give the Fiero a shot at the qtr mile tonight.
Post by jdv »
What track?
Orlando
Only got one run
Fucking cruising after the 330! :good:
The car is street-driveable, right?
Did you trailer it just in case of a breakdown away from home, so you wouldn't be stuck?
Yes the car is streetable. I can drive it anywhere. We towed just in case the trans blew up or if engine decided to quit. Precautionary thing.
Nice numbers!
nice, hopefully with my new fuel system I'll be getting into the 11's, unfortunately, my local track is closed until march, so I won't know for sure until then.
60-130 time in 6.3.
Compared to a stock 2019 zr1
https://youtu.be/ndYBK1JvL5s
Oh man. That's gonna piss off a ton of people over there. LMAO.
lol, you're welcome.
Edit:
it appears as though I was downvoted on the forum since that post, the arrow on my ratings bar is red now... lol!
ericjon262 wrote: Fri Nov 25, 2022 5:32 am lol, you're welcome.
Hey, I helped too!
https://youtu.be/wUZxSf_P2r0?t=9
Edit:
Threw you a positive rating....cuz... facts, data, evidence.......damn...... really pfiffle?
pmbrunelle wrote: Fri Nov 25, 2022 6:27 pm
Hey, I helped too!
you did! not going to lie, I'm kinda surprised there hasn't been a comment made about it yet.
Thanks for keeping the list going, it's nice to have a basis for comparison mod for mod, with verified entries.
draven wrote: Sat Nov 26, 2022 11:22 am
Edit:
yeah, at this point, I find it humorous, I used to take it a little more seriously, but the longer I've been there, the more I realized that the ratings bar is just a pissing contest.
Cool! Really enjoying the vids. The 1/4 mile data analysis was great.
Too bad you were only able to do one run in five hours. Was the track that busy?
When I study datalogs of my car, I have the same ~0.5 second gearchanges. But 1-2 is slower than the other gearchanges, about 0.8-0.9 s.
Probably the low MOI twin-disc sort of clutch setup would help there, though fast shifts may not matter for the mission profile of your car.
I guess if you try more boost, you'll have to shift into 5th gear!
pmbrunelle wrote: Tue Nov 29, 2022 11:35 pm When I study datalogs of my car, I have the same ~0.5 second gearchanges. But 1-2 is slower than the other gearchanges, about 0.8-0.9 s.
The Getrag has single cone synchros on all gears. The 1-2 and 5 synchros are on the output shaft, 3-4 is on the input shaft. That means that for the 1-2 shift, the synchro has to spin down the clutch disk, but it's working "backwards" through the second gear ratio (2.05:1) to do it, so the MoI of the clutch disk has a 2.05:1 mechanical advantage against the torque the synchro can generate. Yes, lower MoI clutch disks would help with this. For both 2-3 and 3-4 shifts, the synchro is working 1:1 against the MoI of the clutch disk, since the synchro is on the input shaft.
And yeah, an irony of making the car faster is that you lose more acceleration time to gear shifting. Time to raise the rev limiter!
AkursedX
Turbo-boostin!
Post by AkursedX »
That's a solid MPH! Good work!
