Need input on my cylinder compression
yes, and quite frankly for what it costs, I would never put a motor back together without atleast a 3 angle valve grind. Even with the stock valves.
goatnipples2002
Post by goatnipples2002 »
I didn't get a valve job cause I didn't have the cash.
If there is a difference between wet and dry comp test does that mean it is a ring more so than the valves? Do all cylinders show higher when it is tested wet vs dry, no matter the motor?
Clean Feet Pet Clean Up
Pet Waste Removal Omaha
We offer dog waste removal and cat waste removal services.
(402) 320-3824, We service the Omaha, Ne. metropolitan area.
a dry sealing set of rings wont hold as much as a wet seal, therefore, if you see a drastic change when going wet, it points to bad rings. If the change is minimal, then look to valves or head gasket.
goatnipples2002
So what would you say in my case?
Umm did you not read my post? Its right under your original post.
And not getting a valve job done is retarded. Looks like you now know why you should have. Looks like you saving a bit of money months ago, has now caught up with you, making it cost more money now, and more time.
Way to go champ.
Dirty Sanchez
Post by Dirty Sanchez »
If your valves are leaking and you don't have the money to do a valve job, get some lapping compound. You can at least get the valves to seal better if you lap them. All you do is put some of the lapping compound on the edge of the valve, where it would contact the seat, and you gently pull it up against the seat and spin it around. This will make it wear into the seat for a better seal. You should be able to visually verify this. Clean off the compound when you are done lapping and it's ready to use. Of course to do this you need the heads off and the valve springs removed.
Shaun, there is a learning curve with building engines. People make mistakes.
Goatnipples. Read the posts. The answers are all there.
goatnipples2002
Thanks for the lapping compound idea.
Shaun- There's a difference between having $ and not wanting to spend it and just not having it. At the time I was putting my heads together I had no extra $.
Mach10
Post by Mach10 »
Live = Learn.
I would have at least lapped the valves... When you take it apart it'll be clear REALLY quickly if you've got a bad valve seat... If nothing else. :salute:
At least it'll run and drive... It's not using oil right now, right? It'll hit your fuel economy and power output...
But I wouldn't throw boost at it. You'll go from "leaking seat" to "burnt valve" in no time.
goatnipples2002 wrote: Shaun- There's a difference between having $ and not wanting to spend it and just not having it. At the time I was putting my heads together I had no extra $.
If you had no extra money to do them right, then I don't even know why you made an attempt. The heads are so important in the reliability of the motor and power production. If your heads are shitty, your engine wont' run right and won't make any power. They are critical parts!!!! Why cheap out there? Makes no sense.
So do you have the money now? From the sound of your posts you still don't, yet you are still going to try and hack it togethor and pray it works. Then of course you will be the first one to say its a peice of shit for not running right or make the power you were hoping for.
Wait another month or two and save your money and do it right. Or get a second job or something.
The guy was running nitrous on this engine. Its my guess, the valves are already toast in the low numbered cylinders. NO amount of lapping is going to fix that. Why? Because he needs brand new valves AND a valve job.
But hey good luck to ya. What do I know?
Mach10
Post by Mach10 »
Nitrous?
Well, that pretty much guarantees that you're going to find a valve with a melty-looking notch cut out of it.
When the valves leak, you have VERY hot burning fuel dragging a torch across the sealing surface...
It's a bad scene, man...
On the other hand, since it's already farked, just drive it easy for the next month while you save up for a proper head job.
goatnipples2002
I have extra valves laying around so I am not worried if the valves are bad. I am using oil now. It smokes a little. I will be doing a swap in oct./nov. when I get school loans, so I only need it to last until then.
please, school loans are unsecured and will cost a lot more in interest than a small secured personal loan. As in put a lean on your car to pay for engine mods. You will end up paying much less for the same in the end.
goatnipples2002
My interest rate is less than 5% and I owe like 20K as is. My fiero will be what I want....how do I do it...I'm in debt up to my eyeballs.
Mach10
Post by Mach10 »
If you cooked a valve, you will also have cooked the seat.
Plain depressing fact of the matter is that you need to have the head machined and the valve-seats ground--if you're lucky.
If it's BAD, you'll need to have the old seat drilled out and a new seat pressed in ($!), or else use a different head.
DO NOT go into debt for this. Take it from someone who's been there.
Going into debt over a fiero. I think thts funny.
Mach10
Post by Mach10 »
You really are an asshole sometimes. :salute:
:afrocool:
AkursedX
Turbo-boostin!
Post by AkursedX »
Shaun41178(2) wrote:Going into debt over a fiero. I think thts funny.
First rule I made when I bought my first Fiero is that I will never buy anything that I don't have the cash on hand to buy. Getting into debt over a car, especially a Fiero is a costly thing to do. you will NEVER EVER get anything in return for what you put into it.
For the cost of rebuilding your heads or doing any work inside your current engine, you could probably buy another longblock from a yard.
http://www.car-parts.com
